Hello
I am absolutely new to this whole world here and am trying to prototype a project.
I need 2 sensor values each from 2 Arduinos to a 3rd Arduino, which should then display this.
For this, because it also has to be small, I got myself Seeed XIAO NRF52840.
Now, with the help of a stranger (don't ask...) I tried to get the whole thing working, but to be honest I don't even know if it's the right approach.
Here is the code of the central unit:
`#include <ArduinoBLE.h>
#define PERIOD 1000
const char* ServiceUuid = "19b10000-e8f2-537e-4f6c-d104768a1214";
const char* ServiceBattFloatUuid = "19b10001-e8f2-537e-4f6c-d104768a1214";
const char* ServiceTempFloatUuid = "19b10002-e8f2-537e-4f6c-d104768a1214";
const char* ServiceHumdFloatUuid = "19b10003-e8f2-537e-4f6c-d104768a1214";
const char* ServiceIdStringtUuid = "19b10004-e8f2-537e-4f6c-d104768a1214";
BLEDevice *currDev, sensor[2], discovered;
String connected = "";
long lastMillis;
enum {NONE, DISCOVERED, CONNECTED, RECEIVE_DATA, DISCONNECTED};
int state = NONE;
while (!Serial);
currDev = NULL;
if (!BLE.begin()) {
Serial.println("* Starting Bluetooth® Low Energy module failed!");
while (1);
BLE.setDeviceName("Master");
BLE.setLocalName("Master");
BLE.advertise();
Serial.println("Seeed XIAO (Master Node)");
Serial.println(" ");
BLE.setEventHandler(BLEDisconnected, BLEPeripheralDisconnectHandler);
BLE.setEventHandler(BLEConnected, BLEPeripheralConnectHandler);
BLE.setEventHandler(BLEDiscovered, BLEPeripheralDiscoverHandler);
BLE.scanForUuid(ServiceUuid);
lastMillis = millis();
switch (state) {
case NONE: BLE.poll(); break;
case DISCOVERED:
state = NONE;
BLE.stopScan();
if ((currDev != NULL) && (currDev->connected()) && (*currDev != discovered))
currDev->disconnect();
discovered.connect();
case CONNECTED: {
if ((sensor[0] == discovered) || (sensor[1] == discovered)) {
state = RECEIVE_DATA;
Serial.println("* Connected to peripheral device!");
if (!discovered.discoverAttributes()) {
state = NONE;
Serial.println("Attribute discovery failed!");
discovered.disconnect();
BLECharacteristic batteryChar = discovered.characteristic(ServiceBattFloatUuid);
BLECharacteristic temperatureChar = discovered.characteristic(ServiceTempFloatUuid);
BLECharacteristic humidityChar = discovered.characteristic(ServiceHumdFloatUuid);
if ((!batteryChar) || (!temperatureChar) || (!humidityChar)) {
state = NONE;
Serial.println("* Peripheral device does not have required characteristic!");
if (!sensor[0]) {
sensor[0] = discovered;
currDev = &sensor[0];
connected = "left";
else if (!sensor[1]) {
sensor[1] = discovered;
currDev = &sensor[1];
connected = "right";
BLE.stopScan();
batteryChar.setEventHandler(BLEUpdated, batteryLevel);
temperatureChar.setEventHandler(BLEUpdated, temperature);
humidityChar.setEventHandler(BLEUpdated, humidity);
batteryChar.subscribe();
temperatureChar.subscribe();
humidityChar.subscribe();
case RECEIVE_DATA:
BLE.poll();
if ((millis() - lastMillis) > PERIOD) {
if (currDev->connected())
else {
BLE.stopScan();
currDev->connect();
case DISCONNECTED:
if (!sensor[1]) {
if (currDev != NULL)
currDev->connect();
void batteryLevel(BLEDevice device, BLECharacteristic value) {
String name;
float val = 0.0;
value.readValue((byte *)&val, sizeof(float));
Serial.println("battery_level_" + connected + ": " + val);
void temperature(BLEDevice device, BLECharacteristic value) {
String name;
float val = 0.0;
Serial.println("temperature_" + connected + ": " + val);
void humidity(BLEDevice device, BLECharacteristic value) {
String name;
float val = 0.0;
Serial.println("humidity_" + connected + ": " + val);
void BLEPeripheralDiscoverHandler(BLEDevice peripheral) {
if (sensor[0] && sensor[1])
return;
Serial.print("Discover event, Peripheral : ");
Serial.println(peripheral.deviceName());
discovered = peripheral;
state = DISCOVERED;
void BLEPeripheralConnectHandler(BLEDevice peripheral) {
state = CONNECTED;
void BLEPeripheralDisconnectHandler(BLEDevice peripheral) {
// central disconnected event handler
Serial.println("Disconnected event, Peripheral");
//BLE.scanForUuid(ServiceUuid);
state = NONE;
if ((currDev != NULL) && (*currDev == peripheral)) {
if ((currDev == &sensor[0]) && (sensor[1])) {
else {
connected = "left";
state = DISCONNECTED;
and here the code of the peripherals:
BLEService service(ServiceUuid);
//BLEStringCharacteristic idCharacteristic(ServiceIdStringtUuid, BLERead, 64);
BLEFloatCharacteristic batteryCharacteristic(ServiceBattFloatUuid, BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic temperatureCharacteristic(ServiceTempFloatUuid, BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic humidityCharacteristic(ServiceHumdFloatUuid, BLERead | BLEWrite | BLENotify);
String name = "right";
while (!Serial);
if (!BLE.begin()) {
Serial.println("- Starting Bluetooth® Low Energy module failed!");
while (1);
BLE.setLocalName(name.c_str());
BLE.setDeviceName(name.c_str());
BLE.setAdvertisedService(service);
//service.addCharacteristic(idCharacteristic);
service.addCharacteristic(batteryCharacteristic);
service.addCharacteristic(temperatureCharacteristic);
service.addCharacteristic(humidityCharacteristic);
BLE.addService(service);
BLE.advertise();
batteryCharacteristic.writeValue(0);
temperatureCharacteristic.writeValue(0);
humidityCharacteristic.writeValue(0);
//idCharacteristic.writeValue(name);
Serial.println("Seeed XIAO (Sensor Node) - " + name);
Serial.println("");
BLEDevice central = BLE.central();
if (central) {
while (central.connected()) {
float batt = ((float)random(1000000)) / 1000000UL;
float temp = ((float)random(1000000)) / 2000000UL;
float humid = ((float)random(1000000)) / 1000000UL;
batt = (batt * 100);
temp = (temp * 200) - 100;
humid = (humid * 100);
batteryCharacteristic.writeValue(batt);
temperatureCharacteristic.writeValue(temp);
humidityCharacteristic.writeValue(humid);
It works ok, but it's unstable as hell (disconnects after a few seconds).
21:21:56.734 -> Discover event, Peripheral :
21:21:56.842 -> * Connected to peripheral device!
If anyone can help me get on the right track (and even if I have to throw everything over) - I would be extremely grateful.
This state has taken me 2 days and I have no idea if everything is for the trash
Thank you & best regards, Raphael
