BLECentralRole
I am using the BLECentralRole library and the "scanner" example by Chiara Ruggeri.
This works great and this call "peer.printAdvertisement();"
prints the entire advertising packet received:
Received adverstisement packet from node da:b7:3f:65:6d:78
RSSI -50 (dBm). Non connectable undirected node
Flags : BrEdrNotSupported
Manufacturer data: 0x590002150112233445566778899AABBCCDDEEFF001020304C3
Scan response received from node da:b7:3f:65:6d:78
Complete Local Name: ECO
How can I extract/parse just the:
MAC address
Complete Local Name
RSSI
from the advertising packet?
Please show your code. Most of us will not dig the web to find the example. And add a link to the library.
If it's in a c-style string, you can use strstr() to find keywords like node, go a number of positions forward and read N characters and store that in a char array; don't forget to add a terminating nul character.
Thanks, here is my code:
  scanner.ino
  Written by Chiara Ruggeri (chiara@arduino.org)
  This example for the Arduino Primo board implements the
  Observer role of the BLE protocol.
  Once scan parameters are set, the sketch continuously
  listen for advertising packets.
  This example code is in the public domain.
#include "BLECentralRole.h"
// download ArduinoLowPower library from library manager to enter in low power mode
#include "ArduinoLowPower.h"
// create central instance
BLECentralRole bleCentral = BLECentralRole();
  // assign event handler for scanReceived event
  bleCentral.setEventHandler(BLEScanReceived, receiveAdvPck);
  // set scan parameters
  // interval and window in 0.625 ms increments
  bleCentral.setScanInterval(3200); // 2 sec
  //bleCentral.setScanWindow(800);  // 0.5 sec
  bleCentral.setScanWindow(1600);  // 1 sec
  // timeout in seconds. 0 disables timeout
  bleCentral.setScanTimeout(0);
  // active scan true to ask for scan response packet
  bleCentral.setActiveScan(true);
  // begin initialization and start scanning
  bleCentral.begin();
  // since we want to realize a low power application we don't handle the
  // BLE_LED in order to save power but put the board in low power mode instead.
  LowPower.sleep();
void receiveAdvPck(BLEPeripheralPeer& peer){
  char advertisedName[31];
  byte len;
  // search for a device that advertises "ECO" name
  peer.getFieldInAdvPck(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, advertisedName, len);
  if(len == 0) // field not found
      peer.getFieldInAdvPck(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, advertisedName, len);
  if(len != 0){ // the field was found
    if(!strcmp(advertisedName, "ECO")) // Name found.
      Serial.print("Name ECO found: ");
      Serial.println(advertisedName);
      // Correct name found - Now get RSSI
      Serial.print("RSSI: ");
      else // Name NOT found.
      Serial.println("Name ECO not found");
You don't call that function. Even if you did, just printing the advertisement is NOT enough to let you extract relevant parts of the advertisement.
You apparently missed the part about posting a link to the library.
MAC address
Complete Local Name
RSSI
I suggesting examining the source code for BLEPeripheralPeer::printAdvertisement and see how it extracts/parses the desired fields.
Thanks,
The link for the Library is:
I am able to extract the CompleteLocalName with:
But I am unable to extract the RSSI and MAC address.
In what file is BLEPeripheralPeer defined? There is no BLEPeripheralPeer.h in the library, and BLEPeripheral.h doesn't define it.
