Arminius_Notus:
Can these flight controllers (such as the quadrino nano) be extended through shields or other external elements or are they quite "rigid"?
There are lots of flight controllers which have open source software (and I believe hardware). These open source projects should be easier to modify than a closed system.
Arminius_Notus:
If we suppose, most of the heating will be on the ground for lift off, battery consumption won't be that high?
Do you have figures on how fast you'll lose heat?
Fortunately turning energy to heat is pretty efficient. If you know how fast you'll be losing the heat, you can figure out how much battery power you'll need.
Arminius_Notus:
What do you think about using an electric arc for heating?
That sounds insanely cool (heavy on the insanely). I'd think there would be lots of ways of converting electrical energy to heat. An electric arc wasn't the first method to come to my mind. I was thinking more of an electric heat gun.
Arminius_Notus:
I understand the safety risk of hot air with flammable fuels which is why I went for idea of 100% electric.
LiPo batteries have great energy density compared with older battery technologies. Still batteries fall far short on energy density when compared with competing fuels.
I think it's safe to say the batteries on an electric vehicle are much heavier than the gasoline carried in conventional vehicles. Electric vehicles still do not have the same range as conventional vehicles.
I think it's a safe bet whenever you see a big gathering of hot air balloons, none of the balloons are heated with electric battery power (at least not while airborne).
It's likely possible to heat the air in a hot air balloon enough to keep it afloat, but the amount of time one can stay airborne will be far shorter when using electric power than if one used conventional fuels.
UKHeliBob:
They already have inputs from the Rx and many of them can use a single wire PPM input.
Some radio systems use digital data between the Tx and Rx. With Spektrum radios (and I imagine many others), it's possible to both send digital information and receive this information from the receivers. Some control boards include connectors for Spektrum satellite receivers. The data come through as asynchronous serial.
Side note (I try this in whenever I think I can get away with it): I took the small transmitter module out of a small "Blade" brand helicopter and used a microcontroller to supply the serial stream of date it expected. I was able to use the microcontroller to read the data from a Wii Nunchuck and convert this data to the protocol expected by the little transmitter module. This allowed me to fly a RC helicopter one handed. I used the joystick for roll and pitch and the accelerometer was used for yaw and throttle. It wasn't any easier to fly a helicopter this way but I sure thought it was cool (hence I mention it whenever I get a chance).
UKHeliBob:
Telemetry data such as voltage and GPS data can be output and fed back to the Tx if required.
Only certain radios use telemetry right? I think it's relatively common to use a second radio system for data. I know data can be send over the FPV's audio channel.
UKHeliBob:
My current favourite is the Naze32 but more are being released all the time.
I've heard Naze controllers are very nice. They're closed systems though aren't they? Nevermind, I decided to use use Google and what do you know, there is open source software for it! Very cool. I'll likely add one to my next HobbyKing order.
I have bunch of airplanes, helicopters, quadcopters and hexacopters, but I'd really like to add some sort of dirigible to my collection of flying things.
