I am trying to blink an led on and off a set number of times (4) by declaring
the: int counter;
and using: for(counter = 0; counter <4; ++counter){}
I cant get the code to work and I am unsure of exactly where to place the: for(counter = 0; counter <4; ++counter){} or even if I am doing the right thing :o
const byte BUTTON = 2;
const byte LED = 13;
unsigned long buttonPushedMillis;
unsigned long ledTurnedOnAt;
unsigned long turnOnDelay = 500;
unsigned long turnOffDelay = 1000;
bool ledReady = false;
bool ledState = false;
 pinMode(BUTTON, INPUT_PULLUP);
 pinMode(LED, OUTPUT);
 digitalWrite(LED, LOW);
 if (digitalRead(BUTTON) == LOW) {
  delay(50);
  buttonPushedMillis = currentMillis;
  ledReady = true;
 if (ledReady) {
  if ((unsigned long)(currentMillis - buttonPushedMillis) >= turnOnDelay) {
   digitalWrite(LED, HIGH);
   ledState = true;
   ledTurnedOnAt = currentMillis;
   ledReady = false;
 if (ledState) {
  if ((unsigned long)(currentMillis - ledTurnedOnAt) >= turnOffDelay) {
   ledState = false;
splext:
I'm unsure what you are trying to achieve with the whole milliseconds thing.
Obviously OP's trying to make all the blinking delay()-less which is good practice even when sometimes it's not actually necessary
splext:
Trying to push you towards the solution
.... that blinks with delay() instead of millis() and uses a for loop when loop()'s looping already? Two bad practices for the price of one.
I'd start by looking at the state change detect tutorial to see how to determine when a button becomes pressed as distinct from is pressed.
Then don't use a for loop approach: when the button becomes pressed, set a counter to 0 and a flag weAreBlinking (initialised false) to true.
Then if weAreBlinking, do the normal millis() stuff for a blink and increment the counter each time. (Slight wrinkle here is that on and off times differ: no biggy, just have a 3rd time called actualInterval or something and each time you toggle the led, set interval to the on or off time as appropriate for the next half-cycle.)
When the counter gets to the right value, make weAreBlinking false. The counter would need to be checked to be double the number of blinks, since a blink is an on and an off.
Some pseudo code. Should get you started as you have reviewed the blink without delay example...
now = millis();
if (button pressed)
 blink_count = 4;
 time_last_blink = now;
 led_on = true;
if (blink count > 0 && now - time_last_blink > blink_delay)
 if (led_on)
  led_on = false;
  blink_count--;
  led_on = true;
i believe this is closer to what you're trying to do.
shorter variables names make the code easier to read
#if 0
#else
const byte BUTTON = A1;
#endif
#define ONÂ LOW
#define OFF HIGH
const unsigned long OnDelay = 500;
const unsigned long OffDelay = 1000;
unsigned long period = 0;
int     count;
bool     state;
  digitalWrite(LED, OFF);
  static unsigned long msecLst = 0;
     unsigned long msec  = millis();
Â
    delay(50);
    msecLst = msec;
    period = OnDelay;
    count = 4;
    state = ON;
    digitalWrite (LED, state);
  if (count && msec - msecLst > period) {
    msecLst = msec;
    if (ON == state) {
      period = OffDelay;
      count--;
      period = OnDelay;
    state = ! state;
    digitalWrite(LED, state);
