blink an led as the message recieved by reciever
2 SimpleReceive
3 This sketch displays text strings received using VirtualWire
4 Connect the Receiver data pin to Arduino pin 11
5 */
#include <VirtualWire.h>
int LED=13;
int pin=11;
Serial.println("setup");
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
vw_set_rx_pin  ( uint8_t  11);
pinMode(LED,OUTPUT);
pinMode(pin,INPUT);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump HEX
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf[i], HEX);
Serial.print("");
Serial.println("");
delay(2000);
error
exit status 1
expected primary-expression before numeric constant
This code is about blinking led as according to message received by receiver. I am using ir sensor in transmitter. I want to blink an led at receiver end when obstacle present at transmitter. But I am unable to code receiver end. Can you code it as mentioned above and remove an error. I will be very thankful to you
you will have to remove the error.
you have mismatched curly braces. Of course you may notice that if you properly formatted/indented your code.
hint:
delay(2000);
is not in your loop() function
Function calls do NOT include types.
