Blink cursor oled ssd1306
Hi, is there a way to blinking a cursor on oled 128x64?
I want to blink a text for just 1 line (or word)
You need to write the letter to the display in the chosen text colour then some time later (half a second maybe) write it again in the background colour, then again after the delay in the text colour. Continue like that.
Sorry i cant get what you said :sob: write again and again?
Yes, write it again and again, first in the text colour, then the background colour.
If i need it to blink for let say 2 minute, i'll have to rewrite it again and again like hundreds line of the same word?
Not hundreds of lines of code, no, you need a loop of some description.
From your questions I suspect you are not familiar with how to write a state machine or non-blocking code, am I correct?
Yes you are correct, and yes i try to make a loop of a single word on my oled. That is i trying to make now
Sadly i cant find any example online
You will find these useful:
Using millis for timing
Demonstration for several things at the same time
Finite state machine tutorial Timer counter state change toggle FSM - all at once - Introductory Tutorials - Arduino Forum
If you understand those techniques a lot of this kind of thing will become easy.
Post the simplest complete code you have to write 1 line of text to your display, don't forget the code tags </>
I have an oled display on a board with a rtc, and use a simple blink without delay approach to flash the : between the hours and minutes. Instead of turning a led off or on as in blink without delay, I toggle a boolean variable which if my memory serves was imaginatively called "showColon" or some such. Then if showColon is true, display ":" and if it's not, display " ".
Can you attach a simple example to use boolean like that?
For example, a line
display.setTextColor(WHITE);
display.setCursor(0, 1);
display.print(F("line one"));
display.setCursor(0, 10);
display.print(F("line two"));
To blink the word "line one" only
Well here's some pseudocode....
if it's time to blink the led (ala blink without delay, normal bwod stuff)
showColon=!showColon // ! means not
if showColon is true, display ":" else display " "
