Blink game
I'm having a little trouble getting this to do what I want it to do...
It's a game with 5 lights and the player is supposed to push a button when the middle LED lights up. Right now, I can't get it to detect the button push unless I hold it. I think I know where the problem is, but my coding level isn't good enough to fix it.
for (int x = 4; x<=12; x=x+2)
          digitalWrite(x, HIGH);
          delay(wait);
          if (digitalRead(ButtonPin) == LOW) //BUTTON PUSHED
In this section, I'm assuming the delay prevents it from detecting any button press. Any suggestions?
Here is the whole code
int ButtonPin = 2;
int pin= 4; // declares LEDs
int pin1= 6;
int pin2= 8;
int pin3= 10;
int pin4= 12;
int wait= 1000; // this will be used for delays
int score = 0; // this will tell you how many times you got it
int wrong = 0; // if your wrong too many times the game starts over
void setup ()
  pinMode(pin, OUTPUT); // sets as output
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
  pinMode(pin3, OUTPUT);
  pinMode(pin4, OUTPUT);
  pinMode(ButtonPin, INPUT_PULLUP);// sets as input
void loop ()
   while (digitalRead(ButtonPin) == HIGH) //Beginnning of the game
       int wrong = 0;
       while(wrong!=5) //runs down the row & lights up the LEDS - start
          delay(wait);
            if (x == 8) //if you pushed the button and you were at 'red' light
              delay(2000);
              BlinkLED(); // USER GOT IT RIGHT
              score= score+1;
              Serial.println("Your Score:");
              Serial.println(score);
              wait = wait*.9;  //decreases the time which led moves to another one -- therefore led getting faster
              digitalWrite(x, LOW);
              wrong= wrong+1; // the wrong count increase
              Serial.println("You got it wrong");
              Serial.println(wrong);
              digitalWrite(4,HIGH); // signifies to the user that she/he is wrong - temporary signal - going to change this later
              digitalWrite(12,HIGH);
              digitalWrite(4,LOW);
              digitalWrite(12,LOW);
              wait = wait*.9;
              if (wrong == 5) // if you get 5 wrong
                  digitalWrite(x, HIGH); // all lights will come on
                  delay(100);
                for (int x = 12; x>=4; x=x-2)
                  delay(100);
                wrong = 0; // resets wrong count
                score = 0; // resests score
                wait = 1000; // resets delay time
          digitalWrite(x,LOW);
void BlinkLED() // SIGNIFIES THAT THE USER IS CORRECT
  digitalWrite(4, HIGH);
  digitalWrite(4, LOW);
Any suggestions?
Use millis() for non blocking timing
Save the millis() value at the time that the start action happens. Then, each time through loop(), check whether the required wait period has elapsed by subtracting the start time from the millis() value now. If the period has elapsed then act accordingly and maybe save the start time for the next activity. If not, then go round loop() again, perhaps taking other actions and/or reading inputs, but don't block the free running of loop().
