Blink LED in a Morse code A fashion?
Hello Folks,
I am attempting to blink a LED in the following pattern:
On for 1 second
Off for 1 second
On for 2 seconds
Off for 1 second
On for 1 second etc.
I am using the following code to blink an LED off and on, this is working fine but I am lost on how to vary the on time every other time it turns on. I would love a clue on what type of code to try.
Many thanks for any ideas.
Code:
void Update()
// check to see if it's time to change the state of the LED
if((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
ledState = LOW; // Turn it off
previousMillis = currentMillis; // Remember the time
digitalWrite(ledPin, ledState); // Update the actual LED
else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
ledState = HIGH; // turn it on
IF it just has to switch back and forth then put this inside the block that turns the led off:
if(OnTime == 1000)
     OnTime = 2000;
     OnTime = 1000;
Many thanks Delta_G,
I'll work on that and get back to you.
Wes
Please use code tags.
One way to do this is to put your on times and your off times into arrays.
const int patternLength = 3;
const unsigned long onTimeMs[patternLength] = {1000, 2000, 1000, 3000};
const unsigned long offTimeMs[patternLength] = {1000, 1000, 2000, 1000};
int patternIndex = 0;
Each time you do the loop, use onTimeMs[patternIndex] and offTimeMs[patternIndex] as the on and off time, and add one to the pattern index. If the pattern index is >= patternLength after adding one, then reset it back to zero.
The example code above will blink like -**---***- continuously.
Alternatively, you can use a single array with all the times in it and keep track of whether you need to be on or off as you step through it. This will do something interesting if the array has an odd length.
Morse code ratios are 1:3:5 (1 for dot length and space between dots/dashs, 3 for dash
length and spaces between letters, 5 for spaces between words).
