Blink LED with function?
When a switch is pressed, it should blink the appropriate LED. There is two LED functions for small and large particles passing through a photo resistor which is being bombarded with a laser.
The serial monitor should count the large and small particles.
How does a single photo resistor count large and small particles?
Using an external switch.
Here is the code i did already, its not correct.
#define A0 0
#define large 9
#define small 4
#define sw 12
void smallParticleBlinkLED()
  int swSmall = digitalRead(sw);
  int sensorValue = analogRead(A0);
  float smallParticleBlinkLED=sensorValue;
  Serial.println(smallParticleBlinkLED);
  while(swSmall == LOW)
    if(smallParticleBlinkLED>=20.46)
      digitalWrite(small, HIGH);
    }else
      digitalWrite(small, LOW);
void largeParticleBlinkLED()
  int swLarge = digitalRead(sw);
  float largeParticleBlinkLED=sensorValue;
  Serial.println(largeParticleBlinkLED);
  while(swLarge == LOW)
  if(largeParticleBlinkLED>=81.84)
    digitalWrite(large, HIGH);
  }else
    digitalWrite(large, LOW);
  //pinMode(9,OUTPUT);
  //pinMode(4, OUTPUT);
  //pinMode(12,INPUT_PULLUP);
 DDRD = (1<<9 | 1<<4); //OUTPUT LED's
 DDRB = (1<<4);      //set INPUT switch
 PORTB |= (1<<4);   //pullup resistor
  Serial.begin(9600);   //begin serial monitor
  largeParticleBlinkLED();
  delay(1);
  smallParticleBlinkLED();
  delay(1);
