This is the first code ive wrote all by myself and it seems to be working but not very good. The led seems to only turn on when i hit a button on the remote like 50 percent of the time. The rest of the time i can see that my ir sensors build in light is blinking when i hit a button but nothing happens. I wasnt sure if i have to declare the receive pin as an input or not. I also wasnt sure if i had to declare my variables and include my libraries in the setup() statement or before it. Im using a attiny 85 processor and not sure what pins can be used for what tasks. I know they all are capable digital read/write, and only some are capable of analog read and write. If anyone has any ideas to make this code better and run more smoothly please let me know.
#include <IRremote.h> #include <IRremoteInt.h>
int RECV_PIN = 3;
int RELAY_PIN = 2;
int LED_PIN = 1;
int BLINK_PIN = 0;
AWOL:
There's a guy here (currently enjoying a brief forum timeout for childish behaviour) with a very similar problem, and a very identical IP address.
Care to comment?
Please remember to use code tags when posting code.
I just read the thread you posted and couldn't find anything useful. My code is working but i just think there might be better way to code it so that it would be more consistent. Like i said its only working when i hit a button sometimes, and the rest of the time it seems like its not sending a signal from the ir sensor to the microprocessor.
Im at work right now so i cant test it out. Wouldnt that cause my BLINK_LED to flash so fast that it would just look like a flicker? Are you saying to get rid of the delay because it causing some sort of blank moment for 250 milliseconds where the microprocessor cant get signal from the ir sensor? Do you have any comment on me defining RECV_PIN as an input? I looked at some examples and they never define a pinMode() for the Ir recieve pin.
No, it would cause the LED to blink so fast, it just looks like it is dim.
I would assume any library using a pin would set the pinMode itself, but I haven't used the IR library for a very long time.
You could check the documentation of the library to see if it is compatible with the processor you're using (timers etc).
Very useful. I think ive implemented this correctly but dont have the IDE here at work to compile it. It probably does set the pinmode automatically. Ill remove it because the example code from the library didnt have it. The only question i have now is if i should use the delay without timer in the part at the bottom where it decodes the signal? When i click a button on my ir remote, my ir sensor blinks really fast. Is there a way to add like a pause between clicks so that its only picking up me pressing the button once?
int RECV_PIN = 3;
int RELAY_PIN = 2;
int LED_PIN = 1;
int BLINK_PIN = 0;
bool SIGNAL_ON = 0;
bool LED_ON = 0;
unsigned long previousMillis = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(RELAY_PIN, OUTPUT);
pinMode(LED_PIN, OUTPUT);
pinMode(BLINK_PIN, OUTPUT);
irrecv.enableIRIn();
digitalWrite(RELAY_PIN, LOW);
digitalWrite(LED_PIN, LOW);
digitalWrite(BLINK_PIN, LOW);
if (currentMillis - previousMillis >= 250) {
LED_ON = !LED_ON;
digitalWrite(BLINK_PIN, LED_ON);
if (irrecv.decode(&results)) {
SIGNAL_ON = !SIGNAL_ON;
digitalWrite(RELAY_PIN, on ? HIGH : LOW);
digitalWrite(LED_PIN, on ? HIGH : LOW);
irrecv.resume();
By convention, all capital letter names are reserved for constants. Constants do not belong on the left side of an equal sign (except when declared, to provide the constant value).
Yes and no. On my ir sensor I have my 5v hooked up to 5v on my breadboard, ground hooked up to ground on my breadboard, and out connected to pin 0 on my microprocessor. Im just not sure if pin 0 can be used for the input that its using. I looked it up and im pretty sure the ir sensor sends digital information, not analog. All the pins on my attiny 85 are capable or digital read and write. So yes i believe that ive wired it correctly.
AWOL i looked and dont see what i forgot. That code came straight from link the other guy posted. Maybe its something simple but i dont see it, sorry about that.
PaulS im also having trouble understanding what youre saying. Are you saying all capitals is wrong and wont work, or it will work but not typical coding context?
Btw thank you all for your help so far. Im hoping when i get off ill be able to put new code on my microprocessor and test it out.
AWOL:
I didn't highlight just that line.
I did that for a reason.
Oh are you talking about defining currentMillis? I defined that variable and the previousMillis variable before the setup() part of the code. Does it not work with it up there?
It will work, but it will cause people that follow conventions, and expect others to follow them, too, to look at you funny.
PaulS:
Okay that makes sense. So only use all capital names when its a constant? A constant is something that doesnt change like my BLINK_PIN or LED_PIN right?
Henrywallace:
Think about it - the global variables get initialised once, before your code has even thought about considering allowing the possibility of running to cross its mind.
AWOL:
So currentMillis cant get defined before setup because the code hasnt even begun to run yet and it hasnt started counting milliseconds? I never really thought about it like that. Can i define currentMillis and previousMillis in the Setup() function? Good catch, thank you.
