Blink position of LCD
Dear all,
I have simple code over here. Here i am trying to blink right most character position so in edit mode to understand which character being editing.
Problem facing:
1)Assume my date is 5/3/2014 , In below program i am saying if date/month between 0-10 then 0 in position else print date/month as it is.
a)If date is 5: it printing 05 while blink function called the 0 is replaced with 5 and again going to 0.
2)In below program i am blinking cursor position. I wanted to blink the character but they are declared as integer.SO question here is how to blink date .
if my date is 5/3/2014 . i wanted to blink 5 , if position switched to month blink month
#include <LiquidCrystal.h>
#include <avr/wdt.h>
static int local_day=5;
static int local_month=3;
static int local_year=2014;
int local_s=10;
static int local_h=3;
static int local_m=2;
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
  wdt_enable(WDTO_8S);
  lcd.begin(16,2);
  lcd.clear();
  Blink_LCD();
enum _Screen_edit_item
  EDIT_DAY,
  EDIT_MONTH,
  EDIT_YEAR,
  EDIT_HOUR,
  EDIT_MINUTE,
  EDIT_SEC
typedef enum _Screen_edit_item EDIT_SCREEN_ITEM;
int Blink_pos[6][2]={
    6,0  }
    9,0  }
    11,0  }
    5,1  }
    8,1  }
    11,1  }
void Blink_LCD()
  int j;
  for( j=0; j<6;j++)
    digitalClockDisplay();
    lcd.setCursor(Blink_pos[j][0],Blink_pos[j][1]);//
    Serial.print(Blink_pos[j][0]);
    Serial.print(" ");
    Serial.println(Blink_pos[j][1]);
    lcd.cursor();
    delay(300);
    switch(j)
    case EDIT_DAY:
      lcd.print(local_day);
    case EDIT_MONTH:
      lcd.print(local_month);
    case EDIT_YEAR:
      lcd.print(local_year);
    case EDIT_HOUR:
      lcd.print(local_h);
    case EDIT_MINUTE:
      lcd.print(local_m);
    case EDIT_SEC:
      lcd.print(local_s);
    lcd.noCursor();
    delay(300);
void digitalClockDisplay()
  // Serial.print(local_s);
  //lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Date:");
  if((local_day>0) &&(local_day<10) )
    lcd.print("0");
  lcd.print("/");
  if((local_month>0) &&(local_month<10) )
    lcd.print("0");
    lcd.print("0");
  lcd.print("/");
  lcd.print("    ");
  lcd.setCursor(0,1);
  lcd.print("Time:");
  if((local_h>0) &&(local_h<10) )
    lcd.print("0");
    lcd.print(local_h);
    lcd.print(local_h);
  lcd.print(":");
  if((local_m>0) &&(local_m<10) )
    lcd.print("0");
    lcd.print(local_m);
    lcd.print(local_m);
  lcd.print(":");
  if((local_s>0) &&(local_s<10) )
    lcd.print("0");
    lcd.print(local_s);
    lcd.print(local_s);
  lcd.print("    ");
Here problem i found that:
if i change blink position from {6,0} to{5,0} the character 0 will be replace with 5 while blink. if i keep it as {6,0} it is not blink.So my question here will be how to concante integer when date and time is below 10.if i don't add zero i cant determine its position.
if no is below 10 how to join two integer and store in variable and print as 05
Look familiar?
