Blink program / Arduino not working
I just got a new Arduino, connected it with the A-B USB cable to my mac, and then selected the correct port and board. I wanted to try out blink, just to see everything was working, before I got into a more advanced project.
The compiling worked, but open hitting verify, the following error messages arose below. I have been googling how to address these, but to no avail. Was hoping I could get some guidance here:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino Mega ADK"
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1411": Resource busy
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude: ser_send(): write error: Bad file descriptor
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
option enabled in File -> Preferences.
Is your arduino a Mega ?
Can you share a screen grab of the port settings in the arduino IDE? do you see Mega written next to this entry?
you should see something like this
In the IDE, select Tools and select "Get Board Info".
See what comes back.
Tom... :slight_smile:
