Hi guys
I`m having little issue with the RGB led blink using millis();
I do get some blink but the on/off intervals are not equall.
Section with issue:
if (currentMillis - previousMillis >= interval) {
setColor(255, 255, 255);
else {
setColor(0, ChangeColour, ChangeColour);
Full Code:
int encoderStartValue = 65000;
int inPin = 4;
int ButtonState = 0;
int dacValue = 0;
bool flag = false;
int yPos = 0;
int Rpin = 9;
int Gpin = 10;
int Bpin = 11;
int ChangeColour = 0;
unsigned long previousMillis = 0;
const long interval = 1000;
int ledState = LOW;
#define encoder0PinA 2
#define encoder0PinB 3
#include <Wire.h>
#include "U8glib.h"
#define MCP4725_ADDR 0x60
volatile unsigned int encoder0Pos = encoderStartValue;
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0 | U8G_I2C_OPT_NO_ACK | U8G_I2C_OPT_FAST); // Fast I2C / TWI
void draw(void) {
// graphic commands to redraw the complete screen should be placed here
u8g.setFont(u8g_font_helvB14);
//u8g.setFont(u8g_font_helvB12);
u8g.drawStr( 0, 14, "FLAG = ");
u8g.setPrintPos(74, 14);
u8g.print(flag);
u8g.drawStr( 0, 40, "DAC = ");
u8g.setPrintPos(62, 40);
u8g.print(dacValue);
u8g.drawStr( yPos, 61, "BalfourBeatty");
void setColor(int Rval, int Gval, int Bval) {
analogWrite(Rpin, Rval);
analogWrite(Gpin, Gval);
analogWrite(Bpin, Bval);
// flip screen, if required
// u8g.setRot180();
pinMode(Rpin, OUTPUT);
pinMode(Gpin, OUTPUT);
pinMode(Bpin, OUTPUT);
pinMode(inPin, INPUT);
pinMode(13, OUTPUT);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
pinMode(encoder0PinA, INPUT);
digitalWrite(encoder0PinA, HIGH); // turn on pull-up resistor
pinMode(encoder0PinB, INPUT);
digitalWrite(encoder0PinB, HIGH); // turn on pull-up resistor
attachInterrupt(0, doEncoder, CHANGE); // encoder pin on interrupt 0 - pin 2
// Serial.begin (9600);
Serial.println("start"); // a personal quirk
Wire.begin();
setColor(255, 0, 255);
//setColor();
// picture loop
u8g.firstPage();
do {
draw();
} while ( u8g.nextPage() );
// If its too fast, you could add a delay
if (yPos < 255) {
// if it's too slow, you could increment y by a greater number
yPos++;
else {
// When the yPos is off the screen, reset to 0.
yPos = 0;
ButtonState = digitalRead(inPin); // read the input pin
digitalWrite(13, flag);
// Serial.println(flag);
// do some stuff here - the joy of interrupts is that they take care of themselves
if (ButtonState == HIGH ) {
flag = !flag;
delay(200);
if (flag == true) {
digitalWrite(5, HIGH);
delay(10);
digitalWrite(7, HIGH);
else {
if (flag == false) {
delay(10);
dacValue = map(encoder0Pos, 0 , 65000, 0, 4096);
ChangeColour = map(dacValue, 0, 4096, 255, 0);
Wire.beginTransmission(MCP4725_ADDR);
Wire.write(64); // cmd to update the DAC
Wire.write(dacValue >> 4); // the 8 most significant bits...
Wire.write(dacValue << 4); // the 4 least significant bits...
Wire.endTransmission();
void doEncoder() {
if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB) && (encoder0Pos < 65000)) {
encoder0Pos += 1000;
if (digitalRead(encoder0PinA) != digitalRead(encoder0PinB) && (encoder0Pos > 1000)) {
encoder0Pos -= 1000;
//Serial.print(encoder0Pos);
Serial.print (dacValue);
Serial.print (" flag = ");
Serial.println (flag);
void doEncoder_Expanded() {
if (digitalRead(encoder0PinA) == HIGH) { // found a low-to-high on channel A
if (digitalRead(encoder0PinB) == LOW) { // check channel B to see which way
// encoder is turning
encoder0Pos = encoder0Pos - 1; // CCW
else {
encoder0Pos = encoder0Pos + 1; // CW
else // found a high-to-low on channel A
else {
Any help greatly appreciated.
Thanks
