Blink sketch not working
I have a question concerning Arduino and downloading sketches via STK200 parallel port and the ATMEGA328 without a serial bootloader. I have it wired up with a 16MHz crystal and I tested it out by writing a quickie C program and downloading it with avrdude. I ran just fine.
I then opened Arduino and loadeed the example Blink sketch and used compile/verify which created Blink.cpp.hex in Linux’s /tmp/build< whole bunch of characters>. I then downloaded Blink.cpp.hex using avrdude, but nothing. I was not running.
Is there something that must be done to run sketches on an ATMEGA328 without a bootloader?
tj
Are you SURE it was not running? If you use an off-the-shelf ATmega328P and don't change the flags it will run at 1 MHz. That would mean your Blink sketch would toggle every 16 seconds. Burning the bootloader with the Arduino IDE takes care of switching to the external 16 MHz clock and pre-scale of 1 rather than the default internal 8 MHz clock and pre-scale of 8.
I changed the lfuse to 0xee, which should be low power crystal oscillator 8-16 Mhz and divide clock by 8 unprogrammed. Installed 16 Mhz crystal and LED circuit from pin 13 to ground.
First I wrote this standard C program and compiled it with avr-gcc
#include <avr/io.h>
#define DELAY 1024
int counter;
int main(void)
// Set Port D pins as all outputs
DDRD = 0xff;
// Set all Port D pins as HIGH
PORTD = 0xff;
while(1){
for(counter=DELAY;counter > 0;counter–);
PORTD = 0x00;
PORTD = 0xff;
return 1;
Of course the LED glowed because of the output frequency, but I confirmed the square wave output with an oscilloscope.
I then started Arduino 1.0, loaded the Blink sketch, ran verify/compile and downloaded Blink.cpp.hex. No output toggling on PIN 13. I checked all port outputs with the scope and found none on any.
I’m stumped.
tj
tjp:
If you want to use that Arduino IDE you should probably set the fuses to match one of the existing Arduino boards:
Arduino Duemilanove: hfuse=0xDA, lfuse = 0xFF, efuse=0x05
Arduino UNO: hfuse=0xDE, lfuse = 0xFF, efuse=0x05 (smaller bootloader)
