Blink without delay - Generating a periodic function with a simpler way
Hi all,
I was wondering if there is any simpler method to generate a periodic delay without using the actual arduino 'delay' function
I have been using blink without delay, but once one tries to add more than two the code becomes a huge mess of variables!
Any solution?
Additionally: I've read a thread some time ago that explained there was an error on the blink without delay function and sugested replacing something on it: Basically using the time the function was scheduled to happen again, rather than the time since it last happened or similar. i cant seem to find that topic again. Anyone knows what i am talking about?
Regards
Replace:
with:
previousMillis += interval;
You could try encapsulating the variables into functions as static variables instead of globals. As long as they only need to be accessed in that function, this will save you some naming conflicts and make the code more easily moved between projects.
Something like this, perhaps?
  pinMode(13, OUTPUT);
boolean delay_without_delaying(unsigned long time) {
  // return false if we're still "delaying", true if time ms has passed.
  // this should look a lot like "blink without delay"
  static unsigned long previousmillis = 0;
  unsigned long currentmillis = millis();
  if (currentmillis - previousmillis >= time) {
    previousmillis = currentmillis;
    return true;
  return false;
boolean delay_without_delaying(unsigned long &since, unsigned long time) {
  if (currentmillis - since >= time) {
    since = currentmillis;
    return true;
  return false;
unsigned long ledtime = 0;
unsigned long atime, btime, ctime, nltime;
  static int ledstate = false;
  if (delay_without_delaying(ledtime, 500)) {
    ledstate = !ledstate;
    digitalWrite(13, ledstate);
  if (delay_without_delaying(atime, 100)) {
    Serial.print("A");
  if (delay_without_delaying(btime, 200)) {
    Serial.print("B");
  if (delay_without_delaying(ctime, 30)) {
    Serial.print("C");
  if (delay_without_delaying(nltime, 1000)) {
    Serial.print("\n");
westfw:
Yes, spot on!
One more question related,
Whats the maximum time I can define without having to declare the variables as long? I am not very familiar with the functions used by the time library, but assuming each variable step equals to one milli, a uint16_t should be good for 65 seconds which is way above anything i will use these kind of functions for.
Unless of course i need to load the exact time of the mili functions, that rolls over every [is it 75 minutes?].
Can someone confirm?
you should use unsigned long for your timer variables.
The rollover occurs every 49 days.
this explains how to avid that issue with the use of unsigned long math:
http://playground.arduino.cc/Code/TimingRollover
First you use arrays []
then you look at using struct's/types and then arrays of your own type.
Mark
amvcs08:
Not if you plan your program properly. See several things at a time.
...R
