Blink without delay not working
I'm using an Arduino Pro Micro and HC12 device in a remote control, talking to another device. Works fine...it's only a couple lines of code. I thought it would be good if I had an LED to indicate when the remote was turned on because the batteries I used were small Li-Ion and I didn't want to have to charge them if I didn't have to. So installed an LED and attached it to Pin 10 of the Pro Micro, and because I wanted it to blink at 1 second intervals when the remote joystick was idle OR in use. Therefore I used Blink Without Delay. Despite changing pins, changing timing parameters, my LED blinks at a really fast rate. I put a scope on it and it 25 Hz or 40 mS period. Why? I did notice that the delay used at the end of the joystick Serial.write HAS an effect. If I put delay at 10mS, the period changes to 50 Hz/20mS period. Why?
`/*  Name: MouseRemoteFEV3blink.ino
    By:
    Start Date:    8Jun2023
    Last Rev:      8Jun2023
    MCU:           Arduino
    Hardware:      Arduino ProMicro
    Description:   Remote built into Nunchuk case with HC12
    Vers History: V1.0   Start by Dejan Nedelkovski, www.HowToMechatronics.com
    V1.1 Using HC12 and Software Serial, to keep Serial available for monitor
    V2.0 Added Blink without Delay, using Millis for LED.
#include <SoftwareSerial.h>
SoftwareSerial HC12(9, 8);  //9 to Tx of HC12, 8 to Rx
const int LED= 10;
int ledState = LOW;            // initial state  For Pro Micro, LOW turns it on.
unsigned long previousMillis = 0;  // store last time LED was updated
const long interval = 1000;  // blink rate in milliseconds
int xAxis, yAxis;
  pinMode(LED, OUTPUT);
  HC12.begin(9600);
  xAxis = analogRead(A0);  // Read Joystick X-axis
  yAxis = analogRead(A1);  // Read Joystick Y-axis
  Serial.write(xAxis / 4);  // Dividing by 4 for converting from 0 - 1023 to 0 - 256, (1 byte) range
  Serial.write(yAxis / 4);
  delay(10);
  if (currentMillis - previousMillis >= interval) {
  // if the LED is off turn it on and vice-versa:
  if (ledState == LOW) {
    ledState = HIGH;
    ledState = LOW;
  digitalWrite(LED, ledState);
The closing bracket for the conditional is in the wrong place.
Look again at the example code more closely.
Cattledog, Yeah, I was just returning to this forum to say I found the problem. Made the change, all is well. Thanks for quick response anyway!
If your question has been answered to your satisfaction, please mark the thread as solved.
