Blink Without Delay Sandbox
Hi All,
I am sandboxing in the blink without delay example, and I'm getting an output that I didn't expect. Here is the code that works as anticipated (sorry it is slightly insulting, I'm a High School teacher, and this is based on student input):
  Blink without Delay
// constants won't change. Used here to set a pin number:
  const int ledPin = LED_BUILTIN;  // the number of the LED pin
// Variables will change:
  int ledState = LOW;  // ledState used to set the LED
// Character Variables
  char charRead;
  char pangram_1[] = "The five boxing wizards jump quickly";
  char pangram_2[] = "Pack my box with five dozen milk jugs";
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
  unsigned long previousMillis = 0;  // will store last time LED was updated
  unsigned long inputTime = 0;
// constants won't change:
  const long interval = 1000;  // interval at which to blink (milliseconds)
  const long patience = 6000;  // interval at which the program reprompts for input
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  Serial.println("BlinkWithoutDelay_Sandbox.ino");
  Serial.println("this program is kinda mean...");
  Serial.println("Enter a letter");
  // here is where you'd put code that needs to be running all the time.
  // check for user input and mock them
    if(Serial.available()) {
      inputTime = millis(); // record the time of input
      charRead = tolower(Serial.read()); // force lowercase
      Serial.write(charRead); // write user input back to serial
        if (isAlpha(charRead)) {
          switch (charRead) {
            case 'a':
              Serial.print(" ... ");
              Serial.println(pangram_1);
            case 'b':
              Serial.println(pangram_2);
            default:
              Serial.println(" ... Well that was a dumb choice.");
            Serial.println(" ... That's not even a letter, idiot!");
  if (currentMillis - inputTime >= patience) {
    Serial.println("... Waiting on you, dude...");
    inputTime = currentMillis;
  // check to see if it's time to blink the LED; that is, if the difference
  // between the current time and last time you blinked the LED is bigger than
  // the interval at which you want to blink the LED.
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
    Serial.println(currentMillis / 1000);
When I try changing the code so currentMillis is universal and I separate out the code that is running all the time as a stand alone function, everything halts until there is a user input:
  Blink without Delay
  char charRead;
  do_work();
      ledState = HIGH;
      ledState = LOW;
void do_work() {
          switch (charRead) {
            case 'a':
            case 'b':
            default:
    Serial.println("... Waiting on you, kiddo...");
It seems like it is stuck in the do_work function waiting on an input, but I wonder if anyone can help me understand why this happens and how to anticipate and fix it so I can code better in the future.
Thanks!
Do you think that it might be a good idea to update currentMillis somewhere in the sketch ?
Thank you so much!
I was fixated on the function, not the relocation of the variable declaration!
Thanks again!
A second pair of eyes is often useful
Failing that I often explain my code to myself, even though I wrote it
