blink without delay stops after 2878 cycles?!?
Hello,
I am facing a strange behaviour that i cannot wrap my head around. this script stops after 2878 cycles.
#define debugLed 13
int pause = 1000;
int timer = 0;
int counter = 0;
void setup(){
   pinMode(debugLed, OUTPUT);
void loop(){
  if (millis() > pause + timer ) {
    Serial.println(counter);
    counter ++;
    digitalWrite(debugLed, !digitalRead(debugLed));
    timer = millis();
    pause = 10;//random(minWaitTime, maxWaitTime) * 1000;
while using delay(10) works endless(?)
void loop(){
    counter ++;
    delay(10);
any ideas??
btw, i am using an arduino nano
see the BlinkWithouDelay example in IDE. compare it with yours.
you have two things wrong. the data type for millis and the rollover handling .
int timer = 0;
timer = millis();
Oops
All variables involved with millis() should be declared as unsigned long.
Arithmetic involved with millis() should be subtraction, not addition.
omg. thank you so much :smiley:
