Blinking 16x2 LCD
Well not quite blinking in the real sense more like a pulse I have been building up my code and it's working and all has been good - learning quite a bit but I'm stuck on this one, the LCD (16x2 I2C 4 wire) is pulsing and I'm not quite sure it's the code I've looked but the led's on the uno are not pulsing but the LCD is albeit faint but annoying any ideas? I have 3 led's to the 3 data pins for both looks and debugging they do not pulse I've tried power from the board as well as from my bench top power supply
#include <Wire.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27, 16, 2);
int senpin = A0;
  lcd.init(); //initialize the lcd
  lcd.backlight(); //open the backlight
  lcd.begin(16, 2); // set up the LCD's number of columns and rows:
  lcd.clear();
  pinMode(A0, INPUT); //set up analog pin A1 to be input
  pinMode(2, OUTPUT); // red led
  pinMode(3, OUTPUT); // yellow led
  pinMode(4, OUTPUT); // green led
  lcd.setCursor(0, 0); // Sets the cursor to col 0 and row 0
  lcd.print(analogRead(A0)); // Prints value on senpin A0 to LCD
  int senpin = analogRead(A0); //take a sample
  if (senpin < 370 && senpin >= 0) {
    lcd.clear();
    lcd.setCursor(4, 0);
    lcd.print("Low water");
    lcd.setCursor(3, 1);
    lcd.print("Near death!");
    digitalWrite(2, HIGH);
    digitalWrite(3, LOW);
    digitalWrite(4, LOW);
  if (senpin < 600 && senpin >= 370) {
    lcd.clear();
    lcd.setCursor(5, 0);
    lcd.print("I need");
    lcd.setCursor(1, 1);
    lcd.print("A little more!");
    digitalWrite(2, LOW);
    digitalWrite(3, HIGH);
  if (senpin < 1000 && senpin >= 600) {
    lcd.clear();
    lcd.setCursor(1, 0);
    lcd.print("That's enough");
    lcd.print("I'm drowning!");
    digitalWrite(4, HIGH);
    delay (1000);
Ok so I found the issue if it is one it's the delay cycle is there a way to prevent it or is it just something to live with the moisture sensor should have a relatively short delay as when you water a plant it will need immediate response to prevent over watering is this logic on track? I'm willing to listen to options/adjustments to the code/hardware if there is one would just like a general idea not the fix would like to conquer that myself it greatly helps with the learning curve!
Get rid of that cowardly
lcd.clear();
and learn to properly format the output to the display.
You already have some cursor control so you may be OK without actually doing anything else.
Nick_Pyner:
lcd.clear();
HaHa that's my first attempt at integrating the LCD I did hack some of the code from other sketches it was originally setup with a red, yellow and green LED for moisture levels, I don't have a pot to control the contrast maybe because the backlight is on full it's more noticeable?
mrbilky:
No, I think what is noticeable is the bad code you picked up, and no amount of fiddlearsing with the backlight will solve the problem..
I submit the name of the game is to only change that which needs to be changed. Indeed you can be in a position where it makes sense to print to LCD in setup.
