Blinking a blue led when the wrong card is scanned
Hi everyone, for one of my projects i am currently working with an RFID scanner. So i had this idea to turn on a green led if the correct card was put on the scanner and a red led for the wrong card. I also wanted to add a blue led which would work as an alarm (blinking) if the wrong card was put on.
But i seem to get the alarm not working corectly, is there someone who can help me with the alarm? (it also needs to be turned of if the correct card is scanned.
this is the code for the leds i got already:
 if (strID.indexOf("23:6B:DF:3E") >= 0)
    digitalWrite(LED_PINGREEN, HIGH);
    digitalWrite(LED_PINRED, LOW);
    Serial.println("Dit is het goede kaartje"); //right card
  else if(currentMillis - previousMillis >= interval){
    digitalWrite(LED_PINRED, HIGH);
    digitalWrite(LED_PINGREEN, LOW);
    Serial.println("Dit is niet het goede kaartje er komt over: "); //wrong card
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(LED_PINALARM, ledState);
Please post a complete sketch illustrating the problem
Please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
You'll also probably require a state machine type solution, with states, say:
"waiting for card"
"card accepted"
"card rejected"
"card in alarm"
