Blinking a led with increment issue
Hello,
I am trying to Blink an LED with the Blynk app.
Whenever the virtual pin V1 is pushed, it should trigger the Led On & Off 10 times.
Somehow any value that I choosed (10 in this example) is doubled when running the problem.
So here the LED is flashing 20 times.
I cannot figure out what I am doing wrong. I also tried a “for” condition but I have the same issue.
Thanks a lot ,
// Debug console
Blynk.begin(auth, ssid, pass);
pinMode (PINOUT, OUTPUT);
  Blynk.run();
BLYNK_WRITE(V1)
  int buttonState = param.asInt();
  if (param.asInt() == 1);
    i = 0;
    while (i < 10) {
      Serial.println(i);
      digitalWrite(LED, HIGH);
      digitalWrite(LED, LOW);
      i++;
I am not familiar with Blynk but this does not make sense to me
Why set buttonState then never use it ?
What value is returned by param.asInt() when data is available ?
Should that semicolon be there on the end of the if ?
