Blinking in different configurations
Helo
I am just starting with the Arduino Leonardo.
I used found here code
/* Blink Multiple LEDs without Delay
* Turns on and off several light emitting diode(LED) connected to a digital
* pin, without using the delay() function.  This means that other code
* can run at the same time without being interrupted by the LED code.
int POST = 13;                // LED connected to digital pin 13
int KIER = 12;
int STOP = 11;
int value1 = LOW;                // previous value of the LED
int value2 = LOW;
int value3 = LOW;// previous value of the LED
long time1  = millis();
long time2 = millis();
long time3 = millis();
long czasPOST = 1000;           // interval at which to blink (milliseconds)
long czasKIER = 500;
long czasSTOP = 300;
  pinMode(POST, OUTPUT);      // sets the digital pin as output
  pinMode(KIER, OUTPUT);
  pinMode(STOP, OUTPUT);
  unsigned long m = millis();
  if (m - time1 > czasPOST){
    time1 = m;
    if (value1 == LOW)
      value1 = HIGH;
      value1 = LOW;
    digitalWrite(POST, value1);
  if (m - time2 > czasKIER){
    time2 = m;
    if (value2 == LOW)
      value2 = HIGH;
      value2 = LOW;
    digitalWrite(KIER, value2);
  if (m - time3 > czasSTOP){
    time3 = m;
    if (value3 ==LOW)
      value3 = HIGH;
      value3 = LOW;
      digitalWrite(STOP, value3);
and this is going very well, but what to do to...
make for example the POST after 20 repeats light on with no blinking for 1 minute and then again make it blinking for some time or cycle ?
How to make such command? I want to make a testing program for my device and put it on the Attiny85. I saw here that it support 3 outputs.
and another thing...How to make the led more time HIGH than LOW in the blinking script ?
Have a read of this to fully understand what you are doing
http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
think about creating a function for each led. You can call the function as many times as you want
I included an example below:
int KIER = 12;
int STOP = 11;
int value2 = LOW;
unsigned long startTime3;
unsigned long onTime = 1900UL;
unsigned long interval = 2000UL;// this combination turns led off for 100ms of a 2 sec total time
    time1 = m;
    if (value1 == LOW)
      value1 = HIGH;
      value1 = LOW;
    time2 = m;
    if (value2 == LOW)
      value2 = HIGH;
      value2 = LOW;
  blink3(); //your new function
void blink3()
  unsigned long elapsedTime = millis() - startTime3;
  if (elapsedTime < onTime) //on time
    digitalWrite(STOP,HIGH);
  else if (elapsedTime < interval) //total time
    digitalWrite(STOP,LOW);
    startTime3 += interval;
This demo several things at a time may give you some ideas.
...R
ok, i will try to deal with it. Maybe i will put it on 3 chips than on 1.
another question...
I want to make a fade on 3 Attiny pins. The pin 4 is OK but the 0 and 1 is little jerky, it is not a soft fading. How to deal with this and make it soft? i used standard fading code. i know this is all about the PWM
 Fade
 This example shows how to fade an LED on pin 9
 using the analogWrite() function.
 This example code is in the public domain.
int led = 0;
int led2 = 1;
int led3 = 4;
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup()  {
  // declare pin 9 to be an output:
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
// the loop routine runs over and over again forever:
void loop()  {
  // set the brightness of pin 9:
  analogWrite(led, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 255) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(5);
  analogWrite(led2, brightness);
  delay(5);
  analogWrite(led3, brightness);
  delay(5);
nexusprime:
I hope you are not thinking of 3 separate Arduinos to do something that is more easily done with one.
...R
I mine use one attina to control HIGH LOW on pins which will be connected to the VCC of 3 Attinas with different program each. I can use blinking program to turn on and off VCC. I think this is the easiest way.
nexusprime:
How many LEDs do you want to blink? The code in several things at a time could be easily extended to do several.
...R
a lot of leds. 3 line about 12V/350mA each.
Here is schematic for Attiny.
Left side of schematic represent the Attiny because i dont have the chips in iCircuit app
nexusprime:
a lot of leds.
Does that mean 10, 100 or 1000?
Does every one of them need a separate blinking pattern?
...R
nexusprime:
attach a shift register and go nuts
I will be more specific.
I have 3 lines of leds. Each have about 11 leds. Each line require about 350mA and 12v.
Now...
I need 3 different programs for drive all leds in the same time.
First is slow blinking
Seccond is fast blinking
Third is soft fading
I am planing to put 3 programs on 3 chips which will be connected to the resistors and first transistors the pnp transistors in the schematic.
More specific...
I will use 3 attiny pins which will be connected to the transistors, each pin each transistor.
So in ready to go device 9 pin of 3 attines will be connected to the 3 transistors.
This 3 chips will be drived by another 4 chip which will be give them command to start doing thing.
the 4 chip will be connected to the voltage devider.
Yes, i could put the shift register, but using the arduino i can make different times of doing things for each of 3 chips.
This is the whole idea.
As has been pointed out, you can turn 3 sets of LEDs on and off at different rates, including a slow fade, using just one Arduino, so why use 4 of them ?
nexusprime:
That's more or less what I thought. The several things at a time demo pretty much does that out of the box.
...R
how about that jerky fading on two pins 1 and 0 ? How to deal with the PWM during the fading ?
That schematic is utter rubbish.
  1. There are no decoupling capacitors in it.
  2. You do not power processors from potential dividers you use regulators.
If you are having trouble with code then post it, but you have been told how to fix things.
Ok i am up and running. Everything going very well, just make a little tweaks over the divider but it works fine!.
I wrote 3 simple task thanks to the Internet using some tutorials:
int KIER = 12;
int STOP = 11;
int value2 = LOW;
unsigned long onTime = 190UL;
unsigned long interval = 3000UL;// this combination turns led off for 100ms of a 2 sec total time
void blink3()
    digitalWrite(POST,HIGH);
    digitalWrite(POST,LOW);
    digitalWrite(KIER,HIGH);
    digitalWrite(KIER,LOW);
2
int KIER = 12;
int STOP = 11;
int value2 = LOW;
unsigned long onTime = 100UL;
unsigned long interval = 150UL;// this combination turns led off for 100ms of a 2 sec total time
void blink3()
3
#include <avr/io.h>
#include <util/delay.h>
#define LED1_PORT 0
#define LED2_PORT 1
#define LED3_PORT 4
int main(void) {
  // Set the LED port number as output.
  DDRB |= (1 << LED1_PORT);
  DDRB |= (1 << LED2_PORT);
  DDRB |= (1 << LED3_PORT);
uint8_t fade_out = 0;
#define BIAS_MAX 1200
#define BIAS_MIN 1
  uint16_t bias = BIAS_MIN;
  // Begin an infinite loop. This is how most programs work.
  while (1) {
    // Set the LED port bit to "1" - LED will be turned on.
    PORTB |= (1 << LED1_PORT);
    PORTB |= (1 << LED2_PORT);
    PORTB |= (1 << LED3_PORT);
    // Wait a little. The delay function simply does N-number of "empty" loops.
    _delay_loop_2(bias);
    // Set the LED port bit to "0" - LED will be turned off.
    PORTB &= ~(1 << LED1_PORT);
    PORTB &= ~(1 << LED2_PORT);
    PORTB &= ~(1 << LED3_PORT);
    // Wait a little.
    _delay_loop_2(BIAS_MAX - bias);
    if (fade_out == 0) {
      bias++;
      if (bias >= BIAS_MAX - 1) fade_out = 1;
    else {
      bias--;
      if (bias <= BIAS_MIN) fade_out = 0;
    // Do that again ...
  // Return the mandatory for the "main" function value.
  return (0);
Now i am looking for simple solution to make it something like first steep for 1 minute, second for 2 minute, third for 3 minute. Is there a library or something to make it simple and easy ? I saw Your sources but i am still dont know what exactly should i do now.
I am now experimenting with the leOS2 but with no luck. Lack of knowledge is the issue ;/
    #include "leOS2.h"
    leOS2 threads;
    #include <avr/io.h>
#define LED1_PORT 0
#define LED2_PORT 1
#define LED3_PORT 4
int KIER = 12;
int STOP = 11;
int value2 = LOW;
  threads.begin();
  threads.addTask(Test1, threads.convertMs(10000), SCHEDULED_IMMEDIATESTART);
void Test1()
 blink3();
void blink3()
  {delay(1000);
