Hey there, I'm completely new to this whole Arduino UNO thing, and I'm trying to just use the Blink example that has already come with the IDE software used for Arduino UNO.
Here is the error message I get:
Arduino: 1.6.11 (Windows Vista), Board: "Arduino/Genuino Uno"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\Joshua\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path C:\Users\Joshua\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\Joshua\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path C:\Users\Joshua\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'uno' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Joshua\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Joshua\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp\sketch\Blink.ino.cpp" -o "C:\Users\Joshua\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
avr-g++: error: CreateProcess: No such file or directoryexit status 1
Error compiling for board Arduino/Genuino Uno.
I've done nothing to the original code that has already came with the Blink example pre-loaded into the software.
Any ideas on why it is showing me this error?
Thanks in advance.
