Blinking LED from serial
Hello guys, I need to write a program that blinks a LED equal to the number I enter from the keyboard. So far, this program can blink only upto 9 times. How can I increase this to two or three digits?
int x,n;
  pinMode(13,OUTPUT);
  Serial.println("Input");
  if(Serial.available ()>0)
     n=Serial.read();
     for(x=48; x<n; x++)
       Serial.print(x-47);
       Serial.println(": LED");
       digitalwrite(13, HIGH);
       digitalwrite(13, LOW);
I’m using parseInt(), and I had to add a check for isdigit().
// Tested with Arduino 1.6.0 on Arduino Uno
  pinMode(13,OUTPUT);
  Serial.setTimeout(200); // timeout for parseInt
  if( Serial.available() > 0)        // something available ?
    if( !isdigit(Serial.peek()))     // is it a digit ?
      Serial.read();                 // throw away CR LF and other things
    else                             // going to read a number
      int n = Serial.parseInt();     // read integer with timeout
      Serial.print("n = ");
      Serial.println(n);
      for(int i=0; i<n; i++)
        digitalWrite(13, HIGH);
        digitalWrite(13, LOW);
I got one from adafruit website, it also works. It also uses the ‘parseInt()’ function. What does parseInt() does???
Do you have a link to the Adafruit code ? I like to see which one is better ;)
Serial.parseInt() read digits from the Serial stream. It stops when a non-digit is received or when there is a timeout. After that the digits are converted to a normal binary variable.
CR = Carriage Return is '\r' LF = Line Feed is '\n'
Suppose sending this via the serial terminal (not the spaces) : 1 3 5 3 CR LF The 1 3 5 3 are read, and the CR stops the parseInt, so the number 1353 is returned.
Suppose sending : 3 4 6 A timeout will stop parseInt, an the number 346 is returned.
The original code was for running a stepper motor using L298n, I have modified it for blinking a LED:
int x, pin1=13;
pinMode(pin1, OUTPUT);
Serial.println(“Input:”);
if(Serial.available())
int steps= Serial.parseInt();
for(x=0;x<steps;x++)
Serial.print(x+1);
delay(100);
delay(100);
