Blinking LED sketch to work on Arduino DUE
Hi -
It seems I got a problem in my Arduino DUE.
I followed the instruction to connect the board. "ON" and "L" lights are on.
I got the following message on Serial Monitor:
Sketch uses 10,340 bytes (1%) of program storage space. Maximum is 524,288 bytes.
Erase flash
Write 10420 bytes to flash
0% (0/41 pages)
[======= ] 24% (10/41 pages)
[============== ] 48% (20/41 pages)
[===================== ] 73% (30/41 pages)
[============================= ] 97% (40/41 pages)
[==============================] 100% (41/41 pages)
Verify 10420 bytes of flash
0% (0/41 pages)
Verify successful
Set boot flash true
CPU reset.
I spent time trying to get solutions, but it seems it is a common issue for others without a solution.
HELP ME! What should I do? Can you ship another one to me?
Thanks,
Michael
changks:
You haven't stated the problem.
changks:
To avoid confusion: That is not the serial monitor. That is the output console. The serial monitor is different and must be opened separately.
changks:
Verify successful
Set boot flash true
CPU reset.
This is not an error.
changks:
This is not a customer service support forum. If you want a return, you should contact the seller directly.
