Hi
I modified blinking LED program to turn it ON for 1 sec, after that the LED should be OFF,.
The LED is all the time ON.
What is wrong ?
// the setup function runs once when you press reset or power the board
const int ResetPin = PA7;
// initialize digital pin PB1 as an output.
pinMode(PB1, OUTPUT);
pinMode(ResetPin, INPUT_PULLDOWN);
// the loop function runs over and over again forever
digitalWrite(PB1, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(PB1, LOW); // turn the LED off by making the voltage LOW
if (ResetPin, HIGH)
I also just noticed that you commented out the blinking part of your first program:
Unsigned_Arduino:
Just wondering, what is the PA7 const for? I don't see anything declared as PB1 either, hence Jr. member.
Read the datasheet of a microcontroller. The pins are grouped in ports, that is what the P stands for. Next a microcontroller usually has a few ports; those are 'numbered' A, B etc. And lastly within the group, they have a number (e.g. 7).
What ted did not mention is the board he's using. And that's very likely not an AVR based board; the reason for that conclusion is that his code uses INPUT_PULLDOWN.
In an AVR based Arduino, PB1 simply translates to 1 (the second pin on port B; remember counting from 0) as does e.g. PD1; PA7 does not exist on an Uno but does exist in a Mega.
I have no idea what PB1 and PA7 translate to on ted's board.
The pin names have nothing to do with functionality of this program, they are for STM32.
Naw you learn that the difference between AVR and ARM some time is just in the names of the pins. LOL
