Blinking LED's, starting on wrong pin
I cannot for the life of me figure out why mode 2 of my code is starting on pin 3 instead of pin 2. I'm sure its something simple that I'm missing. Cany anyone hep?
If I set Line 130 to currentLed = 8; it will start at pin 2 like I need to, but that doesn't seem appropriate.
#include <Wire.h>
// Pin Definitions
const int buttonPin1 = 12;  // Button 1 (Mode Switch)
const int buttonPin2 = 13;  // Button 2 (Action Trigger)
const int buttonPin3 = 11;  // Button 3 (Increase Delay)
const int buttonPin4 = 10;  // Button 4 (Decrease Delay)
const int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9};  // Pin numbers for the 8 LEDs
const int numLeds = 8;  // Number of LEDs
// Mode Definitions
enum Mode { MODE1, MODE2, MODE3 };
Mode currentMode = MODE1;  // Default to MODE1
// LCD Setup (16x2 with I2C address x27)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Button State Variables
int buttonState1 = 0;
int lastButtonState1 = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int buttonState3 = 0;
int lastButtonState3 = 0;
int buttonState4 = 0;
int lastButtonState4 = 0;
// Timing variables for button debounce
unsigned long lastDebounceTime1 = 0;
unsigned long lastDebounceTime2 = 0;
unsigned long lastDebounceTime3 = 0;
unsigned long lastDebounceTime4 = 0;
unsigned long debounceDelay = 50;  // Debounce time (ms)
// For Mode 1: Blinking delay
int blinkDelay = 200; // Initial delay for blinking in milliseconds
// For Mode 2: Blink Press
int currentLed = 0;  // Start blinking from pin 2
bool buttonPressed = false;  // Flag for button press
int mode2Delay = 100; // Initial delay for Mode 2 in milliseconds
// For Mode 3: On/Off Toggle
bool ledsOn = false;  // Flag to track LED state for Mode 3
  // Initialize pin modes
  pinMode(buttonPin1, INPUT_PULLUP);  // Set button 1 as input with pull-up
  pinMode(buttonPin2, INPUT_PULLUP);  // Set button 2 as input with pull-up
  pinMode(buttonPin3, INPUT_PULLUP);  // Set button 3 as input with pull-up
  pinMode(buttonPin4, INPUT_PULLUP);  // Set button 4 as input with pull-up
  // Initialize the LED pins as OUTPUT
  for (int i = 0; i < numLeds; i++) {
    pinMode(ledPins[i], OUTPUT);
  // Initialize the LCD
  lcd.init();
  lcd.clear();
  lcd.backlight();
  displayMode();  // Show initial mode and delay
  // Start the serial monitor for debugging
  Serial.begin(960);
  // Read the state of the buttons
  int reading1 = digitalRead(buttonPin1);
  int reading2 = digitalRead(buttonPin2);
  int reading3 = digitalRead(buttonPin3);
  int reading4 = digitalRead(buttonPin4);
  // Handle Mode Switching (Button 1)
  if (reading1 == LOW && (millis() - lastDebounceTime1) > debounceDelay) {
    if (lastButtonState1 == HIGH) {
      // Change mode
      currentMode = static_cast<Mode>((currentMode + 1) % 3);  // Cycle through 3 modes
      displayMode();  // Update the LCD display with the current mode
    lastDebounceTime1 = millis();  // Reset debounce timer
  // Handle Action Trigger (Button 2)
  if (reading2 == LOW && (millis() - lastDebounceTime2) > debounceDelay) {
    if (lastButtonState2 == HIGH) {
      triggerAction();  // Trigger the action for the current mode
    lastDebounceTime2 = millis();  // Reset debounce timer
  // Handle Increase Delay (Button 3) for Mode 2
  if (reading3 == LOW && (millis() - lastDebounceTime3) > debounceDelay) {
    if (lastButtonState3 == HIGH) {
      mode2Delay += 50;  // Increase mode 2 delay by 50ms
      displayMode();  // Update the display
    lastDebounceTime3 = millis();  // Reset debounce timer
  // Handle Decrease Delay (Button 4) for Mode 2
  if (reading4 == LOW && (millis() - lastDebounceTime4) > debounceDelay) {
    if (lastButtonState4 == HIGH && mode2Delay > 50) {
      mode2Delay -= 50;  // Decrease mode 2 delay by 50ms
    lastDebounceTime4 = millis();  // Reset debounce timer
  // Update last button states
  lastButtonState1 = reading1;
  lastButtonState2 = reading2;
  lastButtonState3 = reading3;
  lastButtonState4 = reading4;
void displayMode() {
  // Clear the LCD and show the current mode and delay
  lcd.clear();
  lcd.print("Mode: ");
  switch (currentMode) {
    case MODE1:
      lcd.print("Blink All");
    case MODE2:
      lcd.print("Blink Press");
    case MODE3:
      lcd.print("On/Off");
      // Reset LEDs when switching to Mode 3
      ledsOn = false; // Reset the state
        digitalWrite(ledPins[i], LOW); // Turn off all LEDs
    default:
      lcd.print("Unknown");
      Serial.println("Error: Unknown mode encountered.");
  lcd.setCursor(0, 1);
  if (currentMode == MODE1) {
    lcd.print("Delay: ");
    lcd.print(blinkDelay);
    lcd.print(" ms");
  } else if (currentMode == MODE2) {
    lcd.print(mode2Delay);
    lcd.print(" ms");
    lcd.print("Press Btn2");
void triggerAction() {
  // Perform the action for the selected mode
    case MODE1:
      mode1();  // Blinking mode
    case MODE2:
      mode2();  // Blink on button press mode
    case MODE3:
      mode3();  // On/Off toggle mode
    default:
// Mode 1: Blinking All LEDs
void mode1() {
  Serial.println("Blinking LEDs...");
  // Blink LEDs in series
    digitalWrite(ledPins[i], HIGH);  // Turn the current LED ON
    delay(blinkDelay);  // Wait for the set delay
    digitalWrite(ledPins[i], LOW);   // Turn the current LED OFF
    delay(blinkDelay);  // Wait for the set delay before moving to the next LED
// Mode 2: Blink one LED on each button press
void mode2() {
  // Read the current button state
  buttonState2 = digitalRead(buttonPin2);
  // Check if the button was just pressed (falling edge detection)
  if (buttonState2 == LOW && lastButtonState2 == HIGH) {
    // Wait for debounce time before processing further
    delay(debounceDelay);
    // Turn off the current LED
    digitalWrite(ledPins[currentLed], LOW);
    // Move to the next LED (loop back to after the last LED)
    currentLed++;
    if (currentLed >= numLeds) {
      currentLed = 0;  // Reset to the first LED
    // Turn on the next LED and blink it
    digitalWrite(ledPins[currentLed], HIGH);
    delay(mode2Delay);  // Use mode2Delay for LED blink duration
    digitalWrite(ledPins[currentLed], LOW);  // Turn it off
    buttonPressed = true;  // Mark button as pressed to avoid double triggers
  } else if (buttonState2 == HIGH) {
    // Reset button press flag when button is released
  // Update the last button state for button2
  lastButtonState2 = buttonState2;
// Mode 3: Toggle all LEDs on or off
void mode3() {
  if (buttonState2 == LOW) {
    // Toggle the LEDs on or off
    ledsOn = !ledsOn;
    // Set LEDs based on the toggle state
      digitalWrite(ledPins[i], ledsOn ? HIGH : LOW);
    // Debugging output
    Serial.print("Button pressed. LEDs are now: ");
    Serial.println(ledsOn ? "ON" : "OFF");
    // Wait a bit to allow for the button to be released
    delay(200);
You are clearly aware of the existence of arrays. Why are you not using them consistently?
Have you been able to set serial monitor to match that baud rate?
You seem to be attempting to debounce your buttons without detecting the state change of those buttons. I don't think that will work.
unfortunately I'm a piecemeal coder, I don't do it very often so I tend to do a lot of things that aren't proper, but they seem to work.
Then it sounds like itnis time to learn better. That style won't get you very far and it tends to turn people off from trying to help much because they know you won't understand and are just looking for a line to copy.
Try initialising currentLed to 8
@Delta_G I don't disagree with you, I just don't do it often enough, maybe once or twice a year if that.
so I did initialize the currentLed to 8 and it worked. I just wasn't sure if that was proper.
i get the following output when i instrument your code
triggerAction
mode2: currentLed 0, ledPin 2
i added the following
void mode2() {
    sprintf (s, "mode2: currentLed %d, ledPin %d",
                                currentLed, ledPins [currentLed]);
    Serial.println (s);
did you mean 9600?
