Hey guys,
I’m using an arduino uno for a project and I’m having trouble implementing hardware interrupts. The basic purpose of the project is to add a strobing taillight to a motorcycle. The arduino will intercept the voltage going to the taillight when the brake lever is pressed. It will then trigger a mosfet which will pulse the 12v line for a set amount of time before going steady on (so drivers aren’t annoyed by a constantly blinking light when stopped at a traffic signal). I’ve got the circuitry and code working for this and I’ve pasted it below.
However, I’d like to trigger the strobe through a hardware interrupt rather than be constantly monitoring it inside the main program loop. The completed project will entail more than just the strobing, so I need a way to make sure whatever code is running, it stops as soon as the brake lever is pressed. The problems arises with my use of the millis() function to set the interval between flashes. Since that won’t work inside of an interrupt, I’m stuck. I’ve tried the delayMicrosecond() function with no success and have also tried calling a separate function from within the interrupt in hopes that it would exit the ISR and go immediately to the function.
Now for the question; has anyone successfully done any kind of time based function inside of an interrupt like I’m trying to do with the strobing light? Is there a better way to go about doing it? In my mind, ideally I would like the interrupt to set a trigger of sorts that ends the ISR and jumps to a certain section of code, but that may or may not even be possible.
Any help or guidance would be much appreciated! If you need more of an explanation just let me know.
Thanks
#define OptoPin 2
#define MosfetPin 4
int StrobeFreq = 100; //sets the delay between strobe pulses
int OnTime = 1000; //This is the amount of time that the strobe will flash before going solid
long StartTime;
long CurrentTime;
int BrakeIndex = 0;
pinMode(OptoPin, INPUT);
pinMode(MosfetPin, OUTPUT);
digitalWrite(MosfetPin, LOW);
pinMode(ProgSimLight, OUTPUT);
if(digitalRead(OptoPin) == LOW && BrakeIndex == 0) //12v has been applied (the brake is on) and it already hasn't strobed this time (BrakeIndex)
StartTime = millis();
BrakeIndex = 1; //it has already strobed when the brake was hit this time, so don't do it again
do
digitalWrite(MosfetPin, !digitalRead(MosfetPin));
delay(StrobeFreq);
CurrentTime = millis();
while (CurrentTime < StartTime + OnTime && digitalRead(OptoPin) != HIGH); //it will loop as long as it hasn't hit the strobing time limit or the brake hasn't been released (the signal went high)
if(digitalRead(OptoPin) == LOW) //the brake is still on after the stobing has stopped
digitalWrite(MosfetPin, HIGH);
else //the brake was let go during the strobing so we want to leave the brake light off
BrakeIndex = 0; //the brake was let go, so reset the index so it will strobe the next time
else if (digitalRead(OptoPin) == HIGH) //normal condition (optocoupler is sending 5v to the arduino)
