I am struggling to get an ESP32 to make an LED blink continuously until the switch is disengaged. It will either have a counter and continue blinking until the counter is finished even if the switch is disengaged or it will delay a certain amount of times and then stop before the switch is disengaged. Is there a way to get the LED to blink continuously until the user turns it off with the switch?
case 3:
while(Serial.print("Left Blinker:"); Serial.println(value)){;
digitalWrite(left_blinker, HIGH); // turn the left blinker on (HIGH is the voltage level)
delay(300); // wait for 300 micro-seconds
digitalWrite(left_blinker, LOW); // turn the left blinker off by making the voltage LOW
delay(300); } // wait for 300 micro-seconds
Please have look at this code. You only have to change the pins which you want to use in your project. Most importantly, read and understand about millis().
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 500; //the value is a number of milliseconds
const byte ledPin = 13; //using the built in LED
Serial.begin(115200); //start Serial in case we need to print debugging info
pinMode(ledPin, OUTPUT);
pinMode(7, INPUT_PULLUP);
startMillis = millis(); //initial start time
currentMillis = millis(); //get the current "time" (actually the number of milliseconds since the program started)
if (!digitalRead(7)) {
if (currentMillis - startMillis >= period) //test whether the period has elapsed
digitalWrite(ledPin, !digitalRead(ledPin)); //if so, change the state of the LED. Uses a neat trick to change the state
startMillis = currentMillis; //IMPORTANT to save the start time of the current LED state.
else {
digitalWrite(ledPin, LOW); //if so, change the state of the LED. Uses a neat trick to change the state
