blinking of long LED strips using transistor
hi...I am making a project on strobe effect on levitating water.
for this I need to amplify the voltage 5V provided by the arduino to 12V to glow the LED strip and make it blink at a constant frequency.
I am using transistor BC547 and I have made my circuit with reference to the given link....
void setup{
     pinMode(13,OUTPUT);
void loop{
    digitalWrite(13,HIGH);
I had tried it with single LED and the LED did glow but didn't blink.
The maximum output voltage I am getting is 3.8V which is very less to the desired output voltage needed.
so....can some help me to fix this problem...?
void loop{
Where is the part that turns it off?
    digitalWrite(13,LOW);
Thank you.....It was a silly mistake.
I need a suggestion as I am unable to amplify the input voltage(5V) to 12V and the circuit is the same as mentioned in the given link....
Brief description of the circuit -
I have used transistor BC547 and it's -
Base is connected to pin 13 with a resistor of 1K in series.
Collector is grounded.
Emitter is connected to supply of 5V by arduino and LEDs (which are in series) and a resistor of 1K in series.
Are they wired like this? Your description is not clear.
Using NPN transistors, BC547.
http://www.fairchildsemi.com/datasheets/BC/BC546.pdf
Yes
No. The emitter is grounded.
No. The collector is connected to the -ve or ground of your LED strip and the +12V connected to the +12V of the LED strip. The 12V power ground is connected to the Arduino Ground.
