I am having trouble getting an invalid argument to catch. When a letter other than g or s is entered i need it to kick back invalid. I am not able to get it to catch
proj1_487.ino (1.19 KB)
Why don't you simply test the character received against 'g' or 's', and if it isn't either of those, print an error message?
I tried testing against g or s and it creates an endless print of the invalid
calvinc5:
OK. You realise that we can’t see your code that does this? (Or maybe not. Which seems more likely)
I only have the code that I have done at the moment, did not save the comparison when it did not work. I also tried it in a switch statement but still not working
The code the OP could have just posted himself if he would bother to read the forum instructions:
/* Project 1 Blink Program
* Spring 2018 Semster
* Febuary 8th
* Calvin Clark
* 11398870
Serial.begin(9600); // Initialize Serial Connection
pinMode(13, OUTPUT); // Making Pin 13 on board as OUTPUT
pinMode(12, OUTPUT);
Serial.println("Enter 'g' to start or 's' to stop LED's");
char input_str; // Initialize input value to compare
input_str = Serial.read();
if(input_str == 'g')
do{
digitalWrite(13, HIGH); // turn ON LED
digitalWrite(12, LOW);
delay(2000); // wait 2 sec
digitalWrite(13, LOW); // turn OFF LED
digitalWrite(12, HIGH);
delay(1000); // wait 1 sec
input_str = Serial.read(); //check value to repeat blinking
} while(input_str != 's');
else if(input_str == 's')
do{
digitalWrite(13, LOW); // 's' entered blinking stopped
} while(input_str != 'g');
else if (Serial.available() > 0)
do{
Serial.println("You have entered an Invalid input.... Try again");
}while(input_str != 'g' || input_str != 's');
Im sorry, I thought it posted when I uploaded the file
You're going about this all wrong. Instead of trapping the code in while loops to wait for something to happen, just set a variable that tells which state you are in and react to that variable. Separate the code taht reads from serial from the code that reacts to it.
Take this for example let's think about what it says to do:
do{
When you pres a g, it says to keep repeating this code as long as the char it reads from serial is not an 's'. It doesn't say anything about doing anything for any letter other than 's'.
do{
This says, if serial is available to read, then print the error message as long as the char in that variable isn't a 'g' or an 's'. But it never says to read anything from Serial in this loop, so if that variable is not a 'g' or an 's' when it starts that loop it will never ever get to be one and this loop becomes infinite.
Your code should look more like this pseudocode:
if input_str == 'g' then blinking = true;
else if input_str == 's' then blinking = false;
else print error message for invalid input
if blinking == true
// blink here, blink without delay style timing
// turn your leds off
Thank you and I am trying that method but it does not seem to be working. Not sure if I set it up wrong
int input_str; // Initialize input value to compare
bool blinking;
while (Serial.available() > 0){
if (input_str == 'g'){
blinking = true;
else if (input_str == 's'){
blinking = false;
else {
switch (blinking){
case true:
case false:
No, if you write like the pseudocode I wrote then there won’t be any while loops in your code.
I also said you should do your blinking without delay. That delay call is going to make it unresponsive.
But I am trying to achieve a constant delay when on
I'm not sure exactly what you mean there but I'm positive you don't need the delay function to make it happen. It's time to google "Blink Without Delay" and start reading tutorials on timing with millis until it makes sense. It's like reading a clock. You already know how to do it. Don't let writing it into code confuse you on the concept.
Please edit you post #9 and put
** **[code]** **
before your code and
** **[/code]** **
after your code.
Your approach is wrong You read a character and next do something if there is another character and nothing if there no other character; this would imply that you have to type two characters to get started.
The below would be a bit better
// character received from serial port; initialised with 0 to indicated nothing received
char c = 0;
// variable to indicate if one should blink or not
bool blinking;
if(Serial.available() > 0)
c = Serial.read();
if (c == 'g')
blinking = true;
else if (c == 's')
blinking = false;
Serial.println("Invalid choice");
if(blinking == true)
Now you have the problem (as already indicated) that your blinking takes 3 seconds. So the next time that you read a character from the serial port while blinking is true is after 3 seconds. As said, study the blink-without-delay example, understand it and apply the principles in your code; Using millis() for timing. A beginners guide might be of help in understanding.
When you apply the blink-without-delay principles, you might have to change the 'blinking' variable to either global (declare before setup) or to a static variable so it's remembered between consecutive
calls to loop(). For the latter
char c = 0;
static bool blinking = false;
You can read Serial Input Basics - updated for more understanding (and examples) on serial communication.
