I thought I would share this. It blinks the RGB lights connected through the WiFi module's pins.
Suggestions welcome - I wasn't really sure what I was doing
# WIFININA spi driver https://github.com/arduino-libraries/WiFiNINA/blob/master/src/utility/spi_drv.cpp
# Commands https://github.com/arduino-libraries/WiFiNINA/blob/master/src/utility/wifi_spi.h
# Adafruit esp32spi https://github.com/adafruit/Adafruit_CircuitPython_ESP32SPI
# NINA 27, 26, 25 are R, G, B
from machine import Pin
from machine import SPI
import time
from micropython import const
_START_CMD = const(0xe0)
_END_CMD = const(0xee)
_ERR_CMD = const(0xef)
_REPLY_FLAG = const(1<<7)
_CMD_FLAG = const(0)
_SET_PIN_MODE = 0x50
_SET_DIGITAL_WRITE = 0x51
_SET_ANALOG_WRITE = 0x52
_GET_DIGITAL_READ = 0x53
_GET_ANALOG_READ = 0x54
ESP_BUSY = Pin(10, Pin.IN)
ESP_RESET = Pin(3, Pin.OUT, False)
ESP_CS = Pin(9, Pin.OUT, True)
ESP_GPIO0 = Pin(2)
ESP_MISO = Pin(8)
ESP_MOSI = Pin(11)
ESP_SCK = Pin(14)
LEDR = 27
LEDG = 25
LEDB = 26
spiwifi = SPI(1, baudrate=100000, sck=ESP_SCK, mosi=ESP_MOSI, miso=ESP_MISO)
def reset():
ESP_GPIO0.init(Pin.OUT)
ESP_GPIO0.value(True)
ESP_CS.high()
ESP_RESET.low()
time.sleep(0.01)
ESP_RESET.high()
time.sleep(0.75)
ESP_GPIO0.init(Pin.IN)
print("ESP32 reset")
def wait_ready():
wait_status = ESP_BUSY.value()
while wait_status:
time.sleep(0.05)
def read_response():
response = []
response_bytes = []
bytes_read = 0
max_read = 32
bytes_read = 0
wait_ready()
ESP_CS.low()
while True:
read_byte = spiwifi.read(1)
response_bytes.append(read_byte)
if read_byte == bytes([_END_CMD]):
break
if read_byte == bytes([_ERR_CMD]):
raise RuntimeError('Error waiting on WiFi Command')
bytes_read += 1
if bytes_read > max_read:
raise RuntimeError('Error waiting on WiFi command')
ESP_CS.high()
num_params = response_bytes[2]
index = 3
for _ in num_params:
length = int.from_bytes(response_bytes[index], "little")
newparam = response_bytes[index+1:index+1+length]
index += 1 + length
response.append(b''.join(newparam))
return response
def send_command(cmd, params=[], num_params=-1):
if num_params < 0:
num_params = len(params)
total_bytes = 3 + num_params + 1
for p in params:
pbytes = bytearray(p)
total_bytes = total_bytes + len(pbytes)
sendbuffer = bytearray(total_bytes)
sendbuffer[0] = _START_CMD
sendbuffer[1] = cmd & ~_REPLY_FLAG
sendbuffer[2] = num_params
index = 3
for p in params:
lenpbytes = len(pbytes)
sendbuffer[index] = lenpbytes
sendbuffer[index+1:index+1+lenpbytes] = pbytes
index += 1+lenpbytes
sendbuffer[index] = _END_CMD
wait_ready()
ESP_CS.low()
spiwifi.write(sendbuffer)
ESP_CS.high()
def set_ninapin_mode(pin, mode):
send_command(_SET_PIN_MODE, [[pin], [mode]])
return read_response()
def ninapin_digital_write(pin, value):
if value == 0:
value = 1
else:
value = 0
send_command(_SET_DIGITAL_WRITE, [[pin], [value]])
reset()
for pin in [LEDR, LEDG, LEDB]:
set_ninapin_mode(pin, Pin.OUT)
ninapin_digital_write(pin, 0)
while True:
time.sleep(0.5)
ninapin_digital_write(LEDR, 1)
ninapin_digital_write(LEDG, 0)
ninapin_digital_write(LEDB, 0)
time.sleep(0.5)
ninapin_digital_write(LEDR, 0)
ninapin_digital_write(LEDG, 1)
time.sleep(0.5)
ninapin_digital_write(LEDB, 1)
