Blinkled - adding watchdog timer?
Can anyone suggest where to place watchdog timer code in the Blinkled webserver? I am trying to add a function that will turn off the LED after an elapsed specified time, unless it is manually turned off first? I have tried placing it in various places and just cannot figure where to place it so that the LED status stays in sync with the actually LED.
Thanks in advance…Arniep
p.s. Here is the code:
// -- c++ --
// Copyright 2010 Ovidiu Predescu ovidiu@gmail.com
// Date: December 2010
// Updated: 08-JAN-2012 for Arduno IDE 1.0 by Hardcore@hardcoreforensics.com
#include <pins_arduino.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
#include <SD.h>
#include <TinyWebServer.h>
#include <Timer.h>
/***VALUES YOU CHANGE/
// The LED attached to PIN X on an Arduino board.
const int LEDPIN = 8;
// pin 4 is the SPI select pin for the SDcard
const int SD_CS = 4;
// pin 10 is the SPI select pin for the Ethernet
const int ETHER_CS = 10;
// Don’t forget to modify the IP to an available one on your home network
byte ip = { 192, 168, 18, 177 };
static uint8_t mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// The initial state of the LED
int ledState = LOW;
void setLedEnabled(boolean state) {
ledState = state;
digitalWrite(LEDPIN, ledState);
inline boolean getLedState() { return ledState; }
boolean file_handler(TinyWebServer& web_server);
boolean blink_led_handler(TinyWebServer& web_server);
boolean led_status_handler(TinyWebServer& web_server);
boolean index_handler(TinyWebServer& web_server);
TinyWebServer::PathHandler handlers = {
// Work around Arduino’s IDE preprocessor bug in handling /* inside
// strings.
// `put_handler’ is defined in TinyWebServer
{"/", TinyWebServer::GET, &index_handler },
{"/upload/" “", TinyWebServer::PUT, &TinyWebPutHandler::put_handler },
{"/blinkled", TinyWebServer::POST, &blink_led_handler },
{"/ledstatus" "
”, TinyWebServer::GET, &led_status_handler },
{"/" “*”, TinyWebServer::GET, &file_handler },
{NULL},
const char* headers = {
“Content-Length”,
NULL
TinyWebServer web = TinyWebServer(handlers, headers);
boolean has_filesystem = true;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
void send_file_name(TinyWebServer& web_server, const char* filename) {
if (!filename) {
web_server.send_error_code(404);
web_server << F(“Could not parse URL”);
TinyWebServer::MimeType mime_type
= TinyWebServer::get_mime_type_from_filename(filename);
web_server.send_error_code(200);
web_server.send_content_type(mime_type);
web_server.end_headers();
if (file.open(&root, filename, O_READ)) {
Serial << F("Read file "); Serial.println(filename);
web_server.send_file(file);
file.close();
web_server << F("Could not find file: ") << filename << “\n”;
boolean file_handler(TinyWebServer& web_server) {
char* filename = TinyWebServer::get_file_from_path(web_server.get_path());
send_file_name(web_server, filename);
free(filename);
return true;
boolean blink_led_handler(TinyWebServer& web_server) {
web_server.send_content_type(“text/plain”);
// Reverse the state of the LED.
setLedEnabled(!getLedState());
Client& client = web_server.get_client();
if (client.available()) {
char ch = (char)client.read();
if (ch == ‘0’) {
setLedEnabled(false);
} else if (ch == ‘1’) {
setLedEnabled(true); //insert timer here?
return true;
boolean led_status_handler(TinyWebServer& web_server) {
client.println(getLedState(), DEC);
return true;
boolean index_handler(TinyWebServer& web_server) {
send_file_name(web_server, “INDEX.HTM”);
return true;
void file_uploader_handler(TinyWebServer& web_server,
TinyWebPutHandler::PutAction action,
char* buffer, int size) {
static uint32_t start_time;
static uint32_t total_size;
switch (action) {
case TinyWebPutHandler::START:
start_time = millis();
total_size = 0;
if (!file.isOpen()) {
// File is not opened, create it. First obtain the desired name
// from the request path.
char* fname = web_server.get_file_from_path(web_server.get_path());
if (fname) {
Serial << F("Creating ") << fname << “\n”;
file.open(&root, fname, O_CREAT | O_WRITE | O_TRUNC);
free(fname);
case TinyWebPutHandler::WRITE:
if (file.isOpen()) {
file.write(buffer, size);
total_size += size;
case TinyWebPutHandler::end:
file.sync();
Serial << F(“Wrote “) << file.fileSize() << F(” bytes in “)
<< millis() - start_time << F(” millis (received “)
<< total_size << F(” bytes)\n”);
file.close();
Serial << F("Free RAM: ") << FreeRam() << “\n”;
pinMode(LEDPIN, OUTPUT);
pinMode(SS_PIN, OUTPUT); // set the SS pin as an output
// (necessary to keep the board as
// master and not SPI slave)
digitalWrite(SS_PIN, HIGH); // and ensure SS is high
// Ensure we are in a consistent state after power-up or a reset
// button These pins are standard for the Arduino w5100 Rev 3
// ethernet board They may need to be re-jigged for different boards
pinMode(ETHER_CS, OUTPUT); // Set the CS pin as an output
digitalWrite(ETHER_CS, HIGH); // Turn off the W5100 chip! (wait for
// configuration)
pinMode(SD_CS, OUTPUT); // Set the SDcard CS pin as an output
digitalWrite(SD_CS, HIGH); // Turn off the SD card! (wait for
// configuration)
// initialize the SD card.
Serial << F(“Setting up SD card…\n”);
// Pass over the speed and Chip select for the SD card
if (!card.init(SPI_FULL_SPEED, SD_CS)) {
Serial << F(“card failed\n”);
has_filesystem = false;
// initialize a FAT volume.
if (!volume.init(&card)) {
Serial << F(“vol.init failed!\n”);
if (!root.openRoot(&volume)) {
Serial << F(“openRoot failed”);
if (has_filesystem) {
// Assign our function to `upload_handler_fn’.
TinyWebPutHandler::put_handler_fn = file_uploader_handler;
// Initialize the Ethernet.
Serial << F(“Setting up the Ethernet card…\n”);
Ethernet.begin(mac, ip);
// Start the web server.
Serial << F(“Web server starting…\n”);
web.begin();
Serial << F(“Ready to accept HTTP requests.\n”);
web.process();
