I'm filling in array serBufLen[32] by using the serial monitor. To fill the array with relevant information I first need to know what format to type this info into the serial monitor? Do I just copy and paste the entire set and press send? E.g. {0x01,0x09,0x01,0x01, 'g'}
start|blinkM|bytes|bytes| command
byte|device|send |receive|
Also, what am I doing by changing values of num_bytes_to_send, num_bytes_to_receive, send_byte0?? What do the commands 'g', 'f', 'W' mean for send_byte0? :.
* BlinkMCommunicator -- Communication gateway between a computer and a BlinkM
* Essentially turns an Arduino to an I2C<->serial adapter
* Command format is:
* pos description
* 0 <startbyte>
* 1 <i2c_addr>
* 2 <num_bytes_to_send>
* 3 <num_bytes_to_receive>
* 4 <send_byte0>
* 5..n [<send_byte1>...]
* Thus minimum command length is 5 bytes long, for reading back a color, e.g.:
* {0x01,0x09,0x01,0x01, 'g'}
* Most commands will be 8 bytes long, say to fade to an RGB color, e.g.:
* {0x01,0x09,0x04,0x00, 'f',0xff,0xcc,0x33}
* The longest command is to write a script line, at 12 bytes long, e.g.:
* {0x01,0x09,0x08,0x00, 'W',0x00,0x01,50,'f',0xff,0xcc,0x33}
* BlinkM connections to Arduino
* PWR - -- gnd -- black -- Gnd
* PWR + -- +5V -- red -- 5V
* I2C d -- SDA -- green -- Analog In 4
* I2C c -- SCK -- blue -- Analog In 5
* 2007-11, Tod E. Kurt, ThingM, http://thingm.com/
#include "Wire.h"
#include "BlinkM_funcs.h"
//#define DEBUG 1
// set this if you're plugging a BlinkM directly into an Arduino,
// into the standard position on analog in pins A2,A3 (power) A4,A5 (i2c)
// otherwise you can set it to false or just leave it alone
const boolean BLINKM_ARDUINO_POWERED = false;
const int CMD_START_BYTE = 0x01;
//int blinkm_addr = 0x09;
int blinkm_addr;
const int serBufLen = 32;
// array that will hold the serial input string
byte serInBuf[serBufLen];
int ledPin = 13;
// initialize serial communication:
Serial.println("BlinkMCommunicator starting up...");
delay(2000);
//identify pin13 as an output
pinMode(ledPin, OUTPUT);
//if powered on using pins A2,A3 for power
if(BLINKM_ARDUINO_POWERED)
//library function
BlinkM_beginWithPower();
//library function to call wire.begin()
BlinkM_begin();
Serial.println("Wire library has begun.");
delay(1000); // wait for power to stabilize
//1. Look for BlinkM led on I2C line if
//blinkm_addr is not identified in the beginning
lookForBlinkM();
//library function
byte rc = BlinkM_checkAddress(blinkm_addr);
if( rc == -1 )
Serial.println("No response"); // FIXME: make this an interogator loop?
delay(2000);
else if( rc == 1 )
Serial.println("I2C address mismatch");
delay(2000);
Serial.println("BlinkMCommunicator ready");
delay(2000);
#ifdef DEBUG
Serial.println("DEBUG MODE: will not allow proper functionality");
#endif
int num;
//2. Read the serial port and create a string out of what you read
num = readCommand(serInBuf);
Serial.println(num);
delay(2000);
if(num == 0) // see if we got a proper command string yet
return; //go to end of loop(){}
digitalWrite(ledPin,HIGH); // say we're working on it
//delay(2000);
byte addr = serInBuf[1];
byte sendlen = serInBuf[2];
byte recvlen = serInBuf[3];
byte* cmd = serInBuf+4;
if(addr == 128)
//3. i2cScanResult called when address is found in BlinkM_scanI2CBus()
//128 == i2c scan command
BlinkM_scanI2CBus(cmd[0], cmd[1], i2cScanResult);
Serial.write(128);
// normal transaction
#ifdef DEBUG
Serial.print(" addr:"); Serial.print(addr,HEX);
Serial.print(" sendlen:"); Serial.print(sendlen,HEX);
Serial.print(" recvlen:"); Serial.print(recvlen,HEX);
Serial.print(" cmd[0..7]:"); Serial.print(cmd[0],HEX);
Serial.print(","); Serial.print(cmd[1],HEX);
Serial.print(","); Serial.print(cmd[2],HEX);
Serial.print(","); Serial.print(cmd[3],HEX);
Serial.print(","); Serial.print(cmd[4],HEX);
Serial.print(","); Serial.print(cmd[5],HEX);
Serial.print(","); Serial.print(cmd[6],HEX);
Serial.print(","); Serial.println(cmd[7],HEX);
#endif
BlinkM_sendCmd(addr, cmd, sendlen);
// if looking for a response, get it
if(recvlen!=0)
byte resp[16];
int rc = BlinkM_receiveBytes(addr, resp, recvlen);
for(int i=0; i < recvlen; i++)
Serial.write(resp[i]);
for(int i=0; i < serBufLen; i++)
serInBuf[i] = 0; // say we've used the string (not needed really)
} // normal transaction
digitalWrite(ledPin,LOW); // show we're done
void lookForBlinkM()
Serial.print("Looking for a BlinkM: ");
//library function
int a = BlinkM_findFirstI2CDevice();
if( a == -1 )
Serial.println("No I2C devices found");
Serial.print("Device found at addr ");
Serial.println(a, DEC);
blinkm_addr = a;
//2. Read a string from the serial and store it in an array
//you must supply the str array variable
//returns number of bytes read, or zero if fail
uint8_t readCommand(byte *str)
uint8_t b;
uint8_t i;
if(!Serial.available())
return 0; // wait for serial
b = Serial.read();
if(b != CMD_START_BYTE)
return 1; // check to see we're at the start
#ifdef DEBUG
Serial.println("startbyte");
#endif
str[0] = b;
i = 100;
while(Serial.available() < 3)
{ // wait for the rest
delay(1);
if( i-- == 0 ) return 0; // get out if takes too long
for( i=1; i<4; i++)
str[i] = Serial.read(); // fill it up
#ifdef DEBUG
Serial.println("header");
#endif
uint8_t sendlen = str[2];
#ifdef DEBUG
Serial.print("cmdlen:"); Serial.println( sendlen, DEC);
#endif
if( sendlen == 0 )
return 0;
i = 100;
while(Serial.available() < sendlen)
// wait for the final part
delay(1);
if(i-- == 0)
return 0;
for( i=4; i<4+sendlen; i++ )
#ifdef DEBUG
Serial.println("got all");
#endif
return 4+sendlen;
//3. Called when address is found in BlinkM_scanI2CBus()
void i2cScanResult( byte addr, byte result )
Serial.write(addr);
Serial.write(result);
