Bliptronic LEDs
So I'm entirely new to the Ardunio, I have some good programming experience but nothing regarding transmitting serial. I ordered a bunch of Bliptronic LEDs with the hopes of recreating the small lighting 'thing' seen here : (need to post once on the forum before I can link).
So, I've followed the connections layed out on that page (blue to GND, red to 5v, etc..) but I just get stable lights being output by my Arduino when I compile and upload the scene, no lighting sequences like in the video on that page.
Any ideas? I'll upload a pic of my current soldering job in a few.
Any help is great! :smiley:
Here's the url: http://bliptronics.com/projects/LEDArduino1.aspx .
Dang that's bright. So bright that it's hard to see YOUR code.
The code is the same from the url I posted above. The code properly uploads to my Arduino but doesn't seem to do anything.
    #include <TimerOne.h>
//Example to control 10 RGB LED Modules.
//Bliptronics.com
//Ben Moyes 2009
//Use this as you wish, but please give credit, or at least buy some of my LEDs!
// Choose which 2 pins you will use for output.
// Can be any valid output pins.
int clockPin = 12;
int dataPin = 11;
byte  SendMode=0;   // Used in interrupt 0=start,1=header,2=data,3=data done
byte  BitCount=0;   // Used in interrupt
byte  LedIndex=0;   // Used in interrupt - Which LED we are sending.
byte  BlankCounter=0;  //Used in interrupt.
unsigned int BitMask;   //Used in interrupt.
//Holds the 15 bit RGB values for each LED.
//You'll need one for each LED, we're using 10 LEDs here.
//Note you've only got limited memory on the Arduino, so you can only control
//Several hundred LEDs on a normal arduino. Double that on a Duemilanove.
unsigned int Display[10];
  byte Counter;
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  // Turn all LEDs off.
  for(Counter=0;Counter < 10; Counter++)
    Display[Counter]=Color(Counter,0,31-Counter);
  show();
  Timer1.initialize(25);           // initialize timer1, 25 microseconds refresh rate.
  Timer1.attachInterrupt(LedOut);  // attaches callback() as a timer overflow interrupt
//Interrupt routine.
//Frequency was set in setup(). Called once for every bit of data sent
//In your code, set global Sendmode to 0 to re-send the data to the pixels
//Otherwise it will just send clocks.
void LedOut()
  switch(SendMode)
    case 3:            //Done..just send clocks with zero data
      digitalWrite(dataPin, 0);
      digitalWrite(clockPin, HIGH);
      digitalWrite(clockPin, LOW);
    case 2:               //Sending Data
      if (BitCount==0)    //First bit is always 1
        {  digitalWrite(dataPin, 1);
            BitMask=0x8000;//Init bit mask
      else if(BitMask & Display[LedIndex])  //If not the first bit then output the next bits (Starting with MSB bit 15 down.)
      BitMask>>=1;
      BitCount++;
      if(BitCount == 16)    //Last bit?
        LedIndex++;        //Move to next LED
        if (LedIndex < 10) //Still more leds to go or are we done?
          BitCount=0;      //Start from the fist bit of the next LED
          SendMode=3;  //No more LEDs to go, we are done!
      // Clock out data.
    case 1:            //Header
        if (BitCount < 32)
        BitCount++;
        if(BitCount==32)
            SendMode++;      //If this was the last bit of header then move on to data.
            LedIndex=0;
            BitCount=0;
    case 0:            //Start
      if(!BlankCounter)    //AS SOON AS CURRENT pwm IS DONE. BlankCounter
        BitCount=0;
        LedIndex=0;
        SendMode=1;
  //Keep track of where the LEDs are at in their pwm cycle.
  BlankCounter++;
void show()
  // The interrupt routine will see this as re-send LED color data.
  SendMode = 0;
// Create a 15 bit color value from R,G,B
unsigned int Color(byte r, byte g, byte b)
  //Take the lowest 5 bits of each value and append them end to end
  return( ((unsigned int)g & 0x1F )<<10 | ((unsigned int)b & 0x1F)<<5 | (unsigned int)r & 0x1F);
// Show a colour bar going up from 0 to 9
void ColorUp( unsigned int ColourToUse)
  byte Counter;
    Display[Counter]=ColourToUse;
    show();
    delay(25);
// Show a colour bar going down from 9 to 0
void ColorDown( unsigned int ColourToUse)
  byte Counter;
  for(Counter=10;Counter > 0; Counter--)
    Display[Counter-1]=ColourToUse;
    show();
    delay(25);
//Input a value 0 to 127 to get a color value.
//The colours are a transition r - g -b - back to r
unsigned int Wheel(byte WheelPos)
  byte r,g,b;
  switch(WheelPos >> 5)
    case 0:
      r=31- WheelPos % 32;   //Red down
      g=WheelPos % 32;      // Green up
      b=0;                  //blue off
    case 1:
      g=31- WheelPos % 32;  //green down
      b=WheelPos % 32;      //blue up
      r=0;                  //red off
    case 2:
      b=31- WheelPos % 32;  //blue down
      r=WheelPos % 32;      //red up
      g=0;                  //green off
  return(Color(r,g,b));
  unsigned int Counter, Counter2, Counter3;
  // Lets show some demo patterns.
  // Just change Display array, then set SendMode to 0
  //Spin LED with colour changing
  for(Counter=0;Counter < 10;Counter++)
    for(Counter2=0; Counter2 < 10 ; Counter2++)
      Display[Counter2] = Wheel(Counter * 10 + Counter2);
      show();
      delay(25);
      Display[Counter2] = Color(0,0,0) ;
      show();
  //Scrolling Rainbow Effect
  for(Counter=0; Counter < 200 ; Counter++)
    Counter3=Counter * 1;
    for(Counter2=0; Counter2 < 10; Counter2++)
      Display[Counter2] = Wheel(Counter3%95);  //There's only 96 colors in this pallette.
      Counter3+=10;
    show();
    delay(25);
  //Color wipes.
  for(Counter=0;Counter < 2;Counter++)
    ColorUp(Color(random(0,32),random(0,32),random(0,32)));
    ColorDown(Color(random(0,32),random(0,32),random(0,32)));
Muffs,
My RGB pixels arrived this morning and I've got a single one running without any problems. So, are you sure that you've got the 'clock' and 'data' lines the correct way around?
Looking at the pixel with the LED upwards, there is an arrow pointing away from one of the capacitors. This is the 'out' side. The other side is, obviously, the 'in' side.
There's a picture here.
I have connected the wires to the 'in' side and the sketch runs fine.
Does this help?
Simon
