„Blitzsimulator“ lightning / thunderstorm simulator
Hey guys,
Testing a lightning detector / thunderstorm detector?
Simulate lightning by radio?
Some time ago I introduced you to the Blitz-O-shield thunderstorm detector for the Arduino UNO.
During development, there was always the problem that when a thunderstorm was needed, there was none nearby.
But how can I simulate lightning?
The "lightning simulator" lightning / thunderstorm simulator was developed precisely for this purpose.
It generates a radio wave which is perceived as lightning by the thunderstorm and lightning detectors.
With a transistor and a coil, which is discharged abruptly, a magnetic wave (spark) is generated which is similar to that of lightning.
The µController used is a PIC12F1572 in a DIP8 package.
The range is up to 10cm.
Is the firmware closed source?
NO !
The current source files can be found in the appendix.
The firmware was created in MikroC and Mikrobasic and can therefore be customised at any time.
Detailed assembly instructions can be found in our (GERMAN) blog.
mfG
FredRam
Maybe an unshielded automotive ignition wire? Lawnmower?
Yes, this will also work.
