block sequence
hello, I have a problem with this program, if I run the command 1 and 2, the Arduino then interprets me both with the delay, but I want to recive the two impulses if followed in a second 1 and 2 do not interpret any. It is possible to do ?
Thanks
      for (int thisPin = 2; thisPin < 5; thisPin++) {
        pinMode(thisPin, OUTPUT);
  if (Serial.available() > 0) {
    int inByte = Serial.read();
    switch (inByte) {
    case '1':
      digitalWrite(2, HIGH);
      digitalWrite(2, LOW);
    case '2':
      digitalWrite(3, HIGH);
      digitalWrite(3, LOW);
    case '3':
      digitalWrite(4, HIGH);
      digitalWrite(4, LOW);
    default:
        digitalWrite(thisPin, LOW);
It's impossible to understand your question. Try to make it more clear.
The delay()s are probably getting in your way because they block the Arduino until they finish.
Look at serial input basics for receiving data without blocking and look at several things at a time to see how to use millis() to manage timing without blocking.
...R
