I have interface a IR sensor with a arduino and i can observe the analog values giving by IR receiver . If the sensor is blocked then it gives a particular range of values and for unblocked it gives another range of values .
Now i need to determine for how long (time) it is giving blocking values. which procedure i can apply ? or which function may help?
Arduino time is given by the millis() or micros() functions.
In this Arduino Reference Page (bookmark, make a folder for it)
The millis() function - milliseconds since startup.
The value returned is type unsigned long, new to this person should use unsigned long variable to do time math with.
Time math should always use the subtraction of end-time minus start-time to get time-difference.
That will ALWAYS work up to the limit of the time variables used. With unsigned long variables, the limit (longest interval you can time) is 49.71~ days.
The usual way it is used:
unsigned long tStart, tWait = 1000UL; // the UL means make the constant 1000 unsigned long
..... other code, setup()
...... some code
if ( millis() - tStart >= tWait ) // if so then the wait is over, run the code inside this if()
// change something
tStart += tWait; // this to set up the next wait then change, perhaps change back/blink the led
...... some code
When I want a single timed event per trigger, not automatic over and over, I use the wait value to tell the code.
...... some code with somewhere it sets up a timed action
if ( tWait > 0 ) // set tWait to 0 to turn the timer code off, > 0 to run it
// change something
tWait = 0; // one-shot event, turn itself off
...... some code
Or just to know how long between things...
unsigned long tStart;
.... possibly some code
if ( digitalRead( myPin, LOW )
tStart = millis(); // save the time NOW to tStart
Serial.print( F( "My pin was LOW for " )); // the extra F() keeps the text stored in flash, not RAM
Serial.print( millis() - tStart );
Serial.println( F( "milliseconds" ));
thanks for your help.I have already go throw this function but can't understand how to integrate this with my concept to get my reasult
Fazlay:
"How long?" type measurements are the simplest type, using millis(). You store the value at time A, and the value at time B, and then subtract B-A.
Fazlay:
unsigned long tStart, tDifference; // time variables, t is for time
So when the sensor changes from unblocked to blocked, you
tStart = millis();
And when it changes from blocked to unblocked, you
tDifference = millis() - tStart;
The duration is in tDifference.
the problem with this method is ..whenever the block state is activated the t_start start to saving that time bt every time the loop runs it updates it time. and just before the unblock state comes it saves that time and subtract it from mills() . so insted of getting real duration i am getting the last t_start and mills() diffrence.
Fazlay:
That isn't at all like the two similar methods that were suggested. You should only save t_start on a rising edge (which I must say is obvious). You have to change your program so that it does that. In reply #4, it is stated as, "when the sensor changes from unblocked to blocked".
Fazlay:
If you want to be a programmer, you have to spend time getting around limitations especially since many will be in your view rather than being "can't". I did some jobs "doing the impossible" where I saw ways that others had not considered.
What I wrote in my last post, I didn't waste words did I?
I have my own change detection technique that only uses 1 byte for both previous and current state.
It involves digital read returning 1 or 0.
byte pinStateHistory; // uses bit 0 for current read and bit 1 for previous read
pinStateHistory = pinStateHistory << 1; // move the bits so bit 0 (current) is now bit 1 (previous)
pinStateHistory = pinStateHistory & 3; // mask off bits 2 to 7
pinStateHistory += digitalRead( myPin ); // the new current read is now in bit 0, last read is in bit 1
switch ( pinStateHistory )
case 0 : // current and previous reads are 0, LOW, no change
// no change, this case usually does nothing but here is where a something would go
case 1 : // change from previous LOW to current HIGH
// change code goes here
case 2 : // change from previous HIGH to current LOW
case 3 : // current and previous reads are 1, HIGH, no change
