Blood Pressure Monitoring (Not able to get the output from Digital BP device)
#include <Wire.h> // i2c library for arduino.
// MACRO Definitions
// start button of the blood pressure monitor device. replaced a transistor.
#define VALVE_PIN (3) // checks if the measurement is done.
#define MEASURE_BEGIN_PIN (4) // indicates that a measurement should start. this can be connected to switch or another MCU or raspberry pi.
volatile byte i2c_data_rx; // indicates there are available data from the i2c bus.
volatile uint16_t count; // indicates the total number of data collected.
volatile uint8_t sys, dia, hr; // stored the measure values: systolic, diastolic and heart rate.
void receiveEvent(int iData) // Interrupt service routine.
if ( iData > 0 )
while ( iData-- )
i2c_data_rx = Wire.read();
//Serial.println(i2c_data_rx);
count++;
if (count == 28)
sys = i2c_data_rx;
if (count == 29)
dia = i2c_data_rx;
if (count == 30)
hr = i2c_data_rx;
pinMode(VALVE_PIN, INPUT);
pinMode(MEASURE_BEGIN_PIN, INPUT);
Wire.begin(0x50); // the address of the EEPROM is 0x50. The arduino should be the same.
Wire.onReceive(receiveEvent); // this is the interrupt initialization for the i2c data.
if (digitalRead(MEASURE_BEGIN_PIN) == 0) // The arduino is instructed to start the measurement.
Serial.println(“Start BP check…”);
//need to secure that the value is already closed.
while (digitalRead(VALVE_PIN) == 0)
Serial.println(“BP On-going…”);
delay(2000);
if (count == 0)
Serial.println(“No data”);
else if (count == 35)
Serial.print(“Blood Presure Data: “);
Serial.print(sys);
Serial.print(”/”);
Serial.println(dia);
Serial.println("");
Serial.println(“error”);
count = 0;
What made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for “Improvements for the web system, applications to moderator, spam, etc.”? I have suggested to the Moderator to move it to the Project Guidance section.
This sort of carelessness makes unnecessary work for the Moderators.
…R
First of all not enough information. What is the blood pressure sensor you are using? Second of all, auto format your code ( Ctrl + t in the IDE ) so that is easier to read. Third of all post in code tags ( </> ). Fourth, your code should be under Programming Questions and not in the “Website and Forum” board as Robin had said…
As this is your first post, it’s better if you “learn how to use the forum”…
