blood pressure sensor
hi
i would like to start an project in blood pressure sensor using arduino yun i don't no which blood pressure sensor is compatible with yun.
so can u help me which blood pressure sensor compatible with yun
mention the name of blood pressure sensor
I don't think there is a "blood pressure sensor". Read up on how electronic blood pressure monitors work. You will want a sensor that is sensitive in the 40-200 mmHg range.
thank you paulcet
Assuming there is a sensor which can measure the pressure- which it will do from the air pressure in the cuff- I think the tricky part is to listen for the Korotkoff sounds so you know when to take the reading: remember there are two parts to a BP number.
Hello
As a long term user of these devices, I believe that they "only" respond to the points at which the cuff pressure overcomes the heart output when it is in systole and diastole. The MD or GP does actually listen with a sphygnomanometer (stethoscope) to the points where as the cuff pressure drops the sounds that Jimbo referred to are where the the cuff overcomes the pressure in the arteries and no blood flow is heard. There is one loss of sound when the diastolic pressure (the lowest value, normally 80-mm mercury) is overcome and the other when the systolic pressure (the highest value, normally 120-mm mercury) is overcome.
You need to do some sums to convert mm mercury into bars and atmosheres to get the units right - you might need a gauge or absolute sensor rather than a differential sensor.
All the commercial BP monitors work with inflatable cuffs that are pumped up to a pressure in excess of the systolic pressure (also sphygnomanometer ) then the pressure is allowed to drop while the sounds are "listened" to. The tricky bit is doing it all with air pressure measurements (look up oscillometric method) where I guess the pressure sensor can pick up the subtle changes at diastole and systole. You might be able to find a way of using a microphone to pick up the arterial blood flow noises
It might be worth looking at some of Libellium's (Cooking Hacks) life science sensors and I believe that Texas Instruments are quite strong in this field.
Good luck and mind your BP.
thank you jimboZa,paulcet,tigger for given your suggestion it will be really helpful for my project.
