blown up arduino (?)
hello everybody,
while working on a project involving an arduino uno and a homemade shield, I accidentally conected the 5v-pin to the outer case of the onboard USB-connector, which I think caused my arduino to blow up. luckily I was powering my arduino through the Vin-pin and not via the USB-connector, since that would probably have damaged my computer.
but, now I cannot upload any codes to the arduino through the USB-connector, although it still can draw power and looks like it is still working, the ON-lights are on when connected, but the TX, RX and L are not.
I was wondering whether or not I could try to program it via the TX and RX pins on the board and an old USB-cable (cut the cable up and connect the wires to GND, 5v, TX & RX accordingly).
so should I try it? or is it better to buy a new Arduino?
thanks in advance!
btw, I fixed the problem on the homemade shield so that it won't shortcircuit again with the outer case of the onboard USB-connector
You may have damaged the onboard regulator. However it will probably still work with the 5v from the USB.
Just use a standard USB cable, don't cut it up etc.
Had you shorted the USB 5v, you probably would not have a problem due to laptop internal protection.
Weedpharma
