I'm sure this has been mentioned before and I've been digging through many threads here and elsewhere but can't find a straight answer.
I'm simply trying to test if the BlueSMiRF I got is working with the Duemilanove.
I currently have the BlueSMiRF connected to 3.3V (not 5V) and have TX to RX on ARduino, and vice versa, and CTS and RTS connected together. And finally GND to GND.
When I simply give the power via USB, I don't see any LEDs flash on the Bluetooth modem. So I'm kinda worried that the BlueSMiRF I got may be busted (Tried to reset, but have been unsuccessful since I only have two hands)
I have the following generic serial test code (was found in many places, but I slightly changed it), which works without the BlueSMiRF.
char val; // variable to receive data from the serial port
int ledpin = 13; // LED connected to pin 48 (on-board LED)
pinMode(ledpin, OUTPUT); // pin 48 (on-board LED) as OUTPUT
Serial.begin(9600); // start serial communication at 9600bps
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == 'H' ) // if 'H' was received
digitalWrite(ledpin, HIGH); // turn ON the LED
Serial.write("hello\n");
else {
digitalWrite(ledpin, LOW); // otherwise turn it OFF
Serial.write("no\n");
delay(100); // wait 100ms for next reading
So is there any related thread that pinpoints to simple SW to test the bluetooth-serial system? Or just the generic wire connection that I might have wrong?
Thanks
