I started a project to make car which could be controlled by a mobile phone using bluetooth.
I used a Arduino Uno for my programming.I also used a L298N motor driver and HC-05 bluetoth module.
This is my sketch:
#define enA 9
#define in1 4
#define in2 5
#define enB 10
#define in3 6
#define in4 7
int xAxis, yAxis;
int x = 0;
int y = 0;
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);*
pinMode(enB, OUTPUT);*
pinMode(in1, OUTPUT);*
pinMode(in2, OUTPUT);*
pinMode(in3, OUTPUT);*
pinMode(in4, OUTPUT);*
Serial.begin(38400); // Default communication rate of the Bluetooth module*
void loop() { -
// Default value - no movement when the Joystick stays in the center*
xAxis = 510;*
yAxis = 510;*
// Read the incoming data from the Smartphone Android App*
while (Serial.available() >= 2) {*
x = Serial.read();*
delay(10);*
y = Serial.read();*
delay(10);*
// Makes sure we receive corrent values*
if (x > 60 & x < 220) {*
xAxis = map(x, 220, 60, 1023, 0); // Convert the smartphone X and Y values to 0 - 1023 range, suitable motor for the motor control code below*
if (y > 60 & y < 220) {*
yAxis = map(y, 220, 60, 0, 1023);*
// Y-axis used for forward and backward control*
if (yAxis < 470) {*
// Set Motor A backward*
digitalWrite(in1, HIGH);*
digitalWrite(in2, LOW);*
// Set Motor B backward*
digitalWrite(in3, HIGH);*
digitalWrite(in4, LOW);*
// Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed*
motorSpeedA = map(yAxis, 470, 0, 0, 470);*
motorSpeedB = map(yAxis, 470, 0, 0, 470);*
else if (yAxis > 550) {*
// Set Motor A forward*
digitalWrite(in1, LOW);*
digitalWrite(in2, HIGH);*
// Set Motor B forward*
digitalWrite(in3, LOW);*
digitalWrite(in4, HIGH);*
// Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed*
motorSpeedA = map(yAxis, 550, 1023, 0, 470);*
motorSpeedB = map(yAxis, 550, 1023, 0, 470);*
// If joystick stays in middle the motors are not moving*
else {*
motorSpeedA = 0;*
motorSpeedB = 0;*
// X-axis used for left and right control*
if (xAxis < 470) {*
// Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value*
int xMapped = map(xAxis, 470, 0, 0, 470);*
// Move to left - decrease left motor speed, increase right motor speed*
motorSpeedA = motorSpeedA - xMapped;*
motorSpeedB = motorSpeedB + xMapped;*
// Confine the range from 0 to 255*
if (motorSpeedA < 0) {*
motorSpeedA = 0;*
if (motorSpeedB > 470) {*
motorSpeedB = 470;*
if (xAxis > 550) {*
// Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value*
int xMapped = map(xAxis, 550, 1023, 0, 470);*
// Move right - decrease right motor speed, increase left motor speed*
motorSpeedA = motorSpeedA + xMapped;*
motorSpeedB = motorSpeedB - xMapped;*
if (motorSpeedA > 470) {*
motorSpeedA = 470;*
if (motorSpeedB < 0) {*
motorSpeedB = 0;*
// Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)*
if (motorSpeedA < 70) {*
motorSpeedA = 0;*
if (motorSpeedB < 70) {*
motorSpeedB = 0;*
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A*
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B*
I uploaded it.
After connecting with the phone the app which I use to control my motors says "267" could not fit into a byte.Pls help me I'm confused :o
