TMRPCM works perfect but by itself. SimpleSDAudio don’t work any term, also my connections are true. (For Mega, 44 for Speaker, 50-51-52 (MISO, MOSI, SCK) and 4 (SD_CS) for Micro SD)
With TMRPCM, my codes are looking like this;
#include <SD.h>
#define SD_ChipSelectPin 53
#include <TMRpcm.h>
#include <SPI.h>
TMRpcm tmrpcm;
#include <Servo.h>
int aci=90,i;
Servo myservo;
int gecikme=40;
HardwareSerial &Bluetooth = Serial1;
// Variables used for incoming data
const byte maxDataLength = 20;
char receivedChars[21] ;
boolean newData = false;
// Pins de HC-SR04
const int trigger_sol = 33;
const int echo_sol = 35;
// Pins de HC-SR04
const int trigger_sag = 37;
const int echo_sag = 39;
// Constants for hardware
const byte m_PIN[] = {23,25,27,29};
boolean m_State[] = {false,false,false,false};
const int on_sol = 22;
const int on_orta = 24;
const int on_sag = 26;
const int hareket_sensoru_sol = 38;
const int hareket_sensoru_sag = 40;
int durum;
int engel_oku1;
int engel_oku2;
int engel_oku3;
myservo.attach(10);
// Configuración de los pines
pinMode(trigger_sol, OUTPUT);
pinMode(echo_sol, INPUT);
pinMode(trigger_sag, OUTPUT);
pinMode(echo_sag, INPUT);
//Engel switchler pull-up olacak
for (byte pin = 0; pin < 4; pin++)
// Set the LED pins for output and make them LOW
pinMode(m_PIN[pin], OUTPUT); digitalWrite(m_PIN[pin],LOW);
pinMode(22,INPUT_PULLUP); // on_sol
pinMode(24,INPUT_PULLUP); //on_orta
pinMode(26,INPUT_PULLUP);
pinMode(38,INPUT);
pinMode(40,INPUT);
kafa_test();
ileri_git(); delay(1000);dur();
geri_git(); delay(200);dur();
sola_don(); delay(200);dur();
saga_don(); delay(200);dur();
// open serial communication for debugging
Serial.print("Sketch: "); Serial.println(__FILE__);
Serial.print("Uploaded: "); Serial.println(__DATE__);
Serial.println(" ");
// open software serial connection to the Bluetooth module.
Bluetooth.begin(9600);
Serial.println("Serial started at 9600");
newData = false;
tmrpcm.speakerPin=46;
if(!SD.begin(SD_ChipSelectPin))
Serial.println("SD fail");
return;
{engel_oku1 = digitalRead(22);
if (engel_oku1 == LOW) {Bluetooth.print("<L,1,0>" );Bluetooth.print("<L,2,0>" );Bluetooth.print("<L,3,1>" );Bluetooth.print("<L,4,0>" );
digitalWrite(23,LOW);digitalWrite(25, HIGH);digitalWrite(27, LOW);digitalWrite(29, HIGH);sistem_test();dur();Bluetooth.print("<L,3,0>" );}
{engel_oku2 = digitalRead(24);
if (engel_oku2 == LOW) {Bluetooth.print("<L,1,0>" );Bluetooth.print("<L,2,1>" );Bluetooth.print("<L,3,0>" );Bluetooth.print("<L,4,0>" );
digitalWrite(23,LOW);digitalWrite(25, HIGH);digitalWrite(27, HIGH);digitalWrite(29, LOW);delay(2000);sistem_test();dur();Bluetooth.print("<L,2,0>" );}
{engel_oku3 = digitalRead(26);
if (engel_oku3 == LOW) {Bluetooth.print("<L,1,0>" );Bluetooth.print("<L,2,0>" );Bluetooth.print("<L,3,0>" );Bluetooth.print("<L,4,1>" );
digitalWrite(23,HIGH);digitalWrite(25, LOW);digitalWrite(27,HIGH);digitalWrite(29, LOW);sistem_test();dur();Bluetooth.print("<L,4,0>" );}
recvWithStartEndMarkers(); // check to see if we have received any new commands
if (newData) { processCommand(); } // if we have a new command do something about it
{ Serial.println(" Hareket Kontrol Ediliyor ");
int buttonState_sol = digitalRead(38);
int buttonState_sag = digitalRead(40);
if (buttonState_sol == LOW) {Serial.println(" SOLDA ENGEL ");
Bluetooth.print("<L,1,0>" );Bluetooth.print("<L,3,1>");Bluetooth.print("<L,2,0>" );Bluetooth.print("<L,4,0>" );tmrpcm.play("91.wav");
digitalWrite(25, HIGH);digitalWrite(29, HIGH);digitalWrite(23, LOW);digitalWrite(27, LOW);
delay(2000);sistem_test();dur();Bluetooth.print("<L,3,0>");}
else if(buttonState_sag == LOW)
{ Serial.println(" SAGDA ENGEL ");
Bluetooth.print("<L,2,0>" );Bluetooth.print("<L,4,1>" );Bluetooth.print("<L,1,0>" );Bluetooth.print("<L,3,0>");tmrpcm.play("91.wav");
digitalWrite(23, HIGH);digitalWrite(27, HIGH);digitalWrite(25, LOW);digitalWrite(29, LOW);delay(2000);sistem_test();dur();Bluetooth.print("<L,4,0>");}
void sola_don() // sola dön
digitalWrite(23, HIGH);digitalWrite(27, HIGH); delay(100);Serial.println(" SOLA donuyorum "); durum=1;
void saga_don()
digitalWrite(25, HIGH);digitalWrite(29, HIGH); delay(100); Serial.println(" SAGA donuyorum ");durum=1;
void ileri_git() // geri git
digitalWrite(23, HIGH);digitalWrite(29, HIGH); delay(100);Serial.println(" ilerliyorum ");durum=1;
void geri_git() // ileri olacak
digitalWrite(25, HIGH);digitalWrite(27, HIGH); delay(100);Serial.println(" GERi Gidiyorum ");durum=1;
void dur()
delay(500); Serial.println(" DURDUM ");
void kafa_test()
for(i=1;i<=15;i=i+1)
aci=aci+5;
myservo.write(aci);
// sets the servo position according to the scaled value
delay(gecikme);
Serial.print("1= "); Serial.println(aci); delay(500);
for(i=1;i<=30;i=i+1)
aci=aci-5;
myservo.write(aci);
delay(gecikme);
Serial.print("2= "); Serial.println(aci); delay(500);
aci=aci+5;
myservo.write(aci);
delay(gecikme);
Serial.print("3: "); Serial.println(aci); delay(500);
delay(2000);
void processCommand()
Serial.print("receivedChars = "); Serial.println(receivedChars);
if (receivedChars[0] == 'L') // do we have a LED command?
// we know the LED command has a fixed length "L10"
// and the value at pos 1 is the LED and the value at pos 2 is 0 or 1 (on/off).
// 0 and 1 is the same as LOW and HIGH so we can use 0/1 instead of LOW/HIGH
byte mnum = receivedChars[1] - 48; // convert ascii to value by subtracting 48
boolean mstatus = receivedChars[2] - 48;
digitalWrite(m_PIN[mnum-1],mstatus);
m_State[mnum-1] = mstatus;
receivedChars[0] = '\0';
newData = false;
void sistem_test()
for(i=1;i<=5;i=i+1)
aci=aci+5;
myservo.write(aci);
delay(gecikme);
Serial.print("test1= "); Serial.println(aci); delay(500);
for(i=1;i<=5;i=i+1)
aci=aci-5;
myservo.write(aci);
delay(gecikme);
Serial.print("test2= "); Serial.println(aci); delay(500);
void recvWithStartEndMarkers()
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
if (Bluetooth.available() > 0)
rc = Bluetooth.read();
if (recvInProgress == true)
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx > maxDataLength) { ndx = maxDataLength; }
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) { recvInProgress = true; }
My PCM file specifications are like this;
8 bit (Unsigned), 16000 Hz, Mono. If I can use Simple SD Audio, actually there is not a problem, but i can’t.
