Bluetooth Arduino Car won't turn
Hello everyone! I am having trouble with my rc car code :( I'm using an Uno, Dual H-Bridge Driver (generic from china), basic gearmotors, and an app that a friend built to control it forwards, backwards, left-motor-only, right-motor-only. It works fine until I go forwards or backwards for too long, and then it will not turn. Meaning, If I reset arduino, I can turn just fine, until I go forwards or backwards, then it will not turn anymore until I reset again... Below is the code I am using. I am not very good at any sort of programming and that is why I am coming to the community. Thanks a lot for any help in advance!
int motorLpin1=2;
int motorLpin2=3;
int motorRpin1=4;
int motorRpin2=5;
int motorLpwm=10;
int motorRpwm=11;
int motorSpeed=125;
int turn=125;
  Serial.flush();
  pinMode(motorLpin1,OUTPUT);
  pinMode(motorLpin2,OUTPUT);
  pinMode(motorRpin1,OUTPUT);
  pinMode(motorRpin2,OUTPUT);
  pinMode(motorLpwm,OUTPUT);
  pinMode(motorRpwm,OUTPUT);
  String input="";
  while(Serial.available()){
    input+=(char)Serial.read();
    delay(5);
  if(input=="n"){
    stp();
  else if(input=="F"){
    fwd();
  else if(input=="R"){
    rev();
  else if(input.indexOf("TL")>-1){
    lft();
  else if(input.indexOf("TR")>-1){
    rght();
  else if(input!=""){
    motorSpeed=input.toInt();
void fwd(){
  analogWrite(motorLpwm,motorSpeed);
  analogWrite(motorRpwm,motorSpeed);
  digitalWrite(motorLpin1,1);
  digitalWrite(motorLpin2,0);
  digitalWrite(motorRpin1,1);
  digitalWrite(motorRpin2,0);
void rev(){
  digitalWrite(motorLpin1,0);
  digitalWrite(motorLpin2,1);
  digitalWrite(motorRpin1,0);
  digitalWrite(motorRpin2,1);
void lft(){
  analogWrite(motorLpwm,motorSpeed-turn);
  analogWrite(motorRpwm,motorSpeed+turn);
void rght(){
  analogWrite(motorLpwm,motorSpeed+turn);
  analogWrite(motorRpwm,motorSpeed-turn);
void stp(){
  analogWrite(motorLpwm,0);
  analogWrite(motorRpwm,0);
  Serial.flush();
Start the serial port. Then, block until all pending output data has been sent. Why? You haven't sent anything yet, so there is nothing pending.
    delay(5);
The delay is pointless. Read all the serial data that has arrived, as fast as possible. Do NOT use Strings.
What is the sending app sending? It should send ONE string when you tell it to send a forward command. It should NOT keep sending the forward command.
Thanks PaulS for your reply! I will try to figure out what it sends tonight and post it here. And thank you for your other code edit suggestions!
