Bluetooth Arduino to program motor for volume dial
Hey, I'm having trouble finding a way that I can write a program and it's pretty extensive, so I'm working with a Bluetooth Arduino board to try and make a motor turn left and right instantly from an app that is connected to a volume dial via a 3-D custom made piece so I can control it all via a compatible app for Arduino, so I want to be able to control the volume of the subwoofers from an app, can anyone help?
Means u want to turn potentiometer clock n anticlock with servo motor?
As per my underatanding...
We may be able to help if you provide a schematic of the wiring, showing all components and power supplies and the code that you tried. Describe what the code actually does and what you want the code to do.
Read the how to use this forum-please read sticky to see how to, properly, post code and some advice on how to ask a good question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
