Hello,
First off I'm a biologist and the only thing I know about electronics is the button end of the battery is the positive end. So please forgive for what will likely be dumb or obvious questions.
I'm trying to make a watch sized device that will take the audio signal from a laptop (chromebook) and activate a vibration motor, so no actual audio output. I am trying to build a prototype using a HC-05 (05).
I can get the 05 to pair with my phone, chromebook, and mac but it will not connect, I get an error or it says “not connected”. So I can't even get to the point of trying to connect the vibrator to the 05 to see if it will activate. I have also been able to TTY into the 05 to check parameters and change the name of the 05.
Everything I have found online regarding using the HC-05 is always associated with an arduino.
So is an arduino, or similar board, required to make any bluetooth module communicate with an audio source?
Is this project even feasible with or with out an arduino?
Thanks for any help or guidance.
