Bluetooth bee +bees shield , it works?
Hi everybody, I’m trying to make work a bluetooth bee module on a bees shield with arduino UNO R3.
http://www.seeedstudio.com/wiki/Bluetooth_Bee
http://www.seeedstudio.com/depot/bees-shield-p-672.html and the wiki http://www.seeedstudio.com/wiki/Bees_Shield
It’s seem not work to me.
I want to make a simple discovery of all nearby MAC address.
I put the jumper BEE_1 RX on PIN 5 and BEE_1 TX pin PIN 6
And the code that i use , is this:
Code:
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 5
#define TxD 6
#define DEBUG_ENABLED  1
char recvChar;
String recvBuf;
String recvAddr;
String recvInq;
SoftwareSerial blueToothSerial(RxD,TxD);
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
  //wait 1 sec and flush the serial buffer
  Serial.flush();
  blueToothSerial.flush();
  Serial.println(" ");
  Serial.println("restarted....");
  Serial.println("Starting BTScan....");
  btScan();
void setupBlueToothConnection()
  blueToothSerial.begin(38400); //Set Bluetooth to 38400
  blueToothSerial.print("\r\n+STWMOD=1\r\n");//set bluetooth to master mode
  blueToothSerial.print("\r\n+STNA=MyBTname\r\n");//set bluetooth name
  blueToothSerial.print("\r\n+STAUTO=0\r\n");// no Auto-connection
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n");//make the master inquire
void btScan()  //scan for devices
  if (blueToothSerial.available())
    recvChar = blueToothSerial.read();
    recvBuf += recvChar;
    if (((recvChar > 47) && (recvChar < 58)) || ((recvChar > 64) && (recvChar < 71)))  // get numbers and A-F only
      recvAddr += recvChar;
      if(recvAddr.length()==12)
        Serial.println(recvAddr);
        recvAddr = "";
i’ve found here http://forum.arduino.cc/index.php?topic=120113.msg917995#msg917995
It’s seems correct, but the blueToothSerial does not seem turn available to me.
My question is:
If the code is correct, it is possible that the two components are not compatible?
What could be wrong?
Thanks in advance
I knew what I had to do. I have to reverse the jumper on the shield. bye
