The topic is related to this hardware:
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=7&products_id=350
I had a lot of problem connecting to it. The connection will remain for very short period and then is dropped and I have to connect again. While connected, I tested sending from my phone to the bee. Everything I sent was successfully received on the serial monitor (I removed atmega so it won't interfere). I know arduino IDE has a problem with its 9600 baud rate and I used termite terminal software.
But when I send from PC to phone, things get garbled too often (like couple times in 10 trials). So I was confused maybe the bee's transmission is too weak? Then I did a test sending a paragraph over from PC to phone using the bee. The last word was "principle." and my received message has instead "princitic princitic princitic principle.principle."
So I guess my question is: does bluetooth has any error checking mechanism to find out something is wrong and request a resend?
Then why does princi*** show up so many times if it is determined to be garbled and many resent seem to have occurred?
Thank you!
