Bluetooth Bee v1.2
hi, the bluetooth Bee v1.2 execute commands AT??
fabiolmessi: hi, the bluetooth Bee v1.2 execute commands AT??
Yes.
PaulS: Yes.
How??
can you post code??
How??
What you use to send AT commands to the bluetooth device depends on how it is connected to the Arduino. For all we know, it is still in a box.
What AT command you send it depends on what you want it to do.
can you post code??
That's your job, since you posted in the Programming section. We'll help you figure out why it doesn't do what you expect, so you can adjust your expectations.
PaulS: What you use to send AT commands to the bluetooth device depends on how it is connected to the Arduino. For all we know, it is still in a box.
What AT command you send it depends on what you want it to do. That's your job, since you posted in the Programming section. We'll help you figure out why it doesn't do what you expect, so you can adjust your expectations.
void setupBlueToothConnection()
    //bluetooth.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
    bluetooth.print("\r\n+STWMOD=1\r\n");
    bluetooth.print("\r\n+STNA=SeeeduinoBluetooth\r\n");
    delay(2000); // This delay is required.
    bluetooth.print("\r\n+INQ=1\r\n");
i have configure Bluetooth be, i need the function discovery, so that you have neighboring mac addresses
There are AT wiki for my modul
